![]() | Home > Maintenance & Mods (L405) > Auto Start Stop Disabled with GAP tool |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2725 ![]() ![]() |
That is what I set but so far it doesn't work on my MY21.5 D350.
jimmie Member Since: 19 Jul 2014 Location: Warsaw Posts: 188 ![]() ![]() ![]() |
try to set ccf "as built" - you can do that with topix or ask gap to give that file*
If last user mode hasn't started working in a couple of weeks and the fault that occurred prior to any CCF changes doesn't re-occur or does re-occur but doesn't have any connection with stop-start disabling then I'll reset that setting to see if the configuration errors then don't return.
if you have wrong configuration. i.e. IMC looks for not existing modules, or could not get correct answer from existing ones then it will restart or initialise again so why you can get unusal long starting of unit. |
The only parameter that could be wrong by my changes is the start-stop last user mode being enabled if the software doesn't allow the setting. However this one from the IMC
if it starts in 30 seconds then is normal. If starts, then after few seconds restarts again or starts over minute then it is not normal.
The displays don't restart and most of the time 30 seconds sounds about right, but sometimes can take a lot longer. If I was parked then I'm gone in under 5 seconds. L405 D350 SE Carpathian Grey D5 19" rims |
