![]() | Home > General > Dirty alloys |
| M44K TS Member Since: 09 Feb 2010 Location: North East U.K. Posts: 1325
Just wax your wheels and the brake dust will be reduced and the wheels will be easier to keep clean 2006 Mercedes CLS
| Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3818
they all do that, almost a 3 ton motor with big discs and big pads = lot of dust |
| kingpleb Member Since: 07 Jun 2011 Location: Maybe here. Maybe there, I get everywhere! Posts: 8455
Wax them and maybe use something like rain'x on them, then just give them a rinse every few days to keep em chipper |
| tboner001 Member Since: 22 Jan 2011 Location: Bucks Posts: 691
Light spray after waxing once a week with 50-50 mix of bilberry and jet wash off done |
| dan_uk_1984 Member Since: 12 Nov 2008 Location: Bude, Cornwall Posts: 4014
I tend to use Autoglym Wheel Sealant @ £4.50 a can it's a bargain. I probably only use it once a month so a can has lasted me over a year so far!
You take the wheels off once a month to spray on ptfe ? Far to many gone... |
I wash them whilst they are on the car. And I dont clean the inside unlike some! |
Nothing wrong with taking wheels off every few months to clean the backs |
But you spray them on the car with Autoglym ? pal of mine did that last year trashed his pads and discs |
| Lee's Dad Member Since: 05 Jun 2011 Location: In with the POPE Posts: 54
Your Pal Didn't read the Directions. Do not spray through wheels onto brake discs or calipers. If unsure then spray product direct to cloth and apply to wheels to avoid spraying brake components. |
As above, I try not to spray through the spokes - that being said, I'm sure I have sprayed some on the discs in the past with no ill effect. It will just burn off as the discs heat up, unless your mate sprayed so much on them that it soaked the pad in them?
| Dixy Member Since: 09 Apr 2009 Location: Somerset Posts: 1123
I noticed this today when cleaning the car. The front wheels in particular seem to have a build up of larger than dust black brake pad on them. The only other time I have seen this sort of thing was when I tried Green stuff pads in Elise.
They make them out of cheese - that way they can change them every time they change the oil. $$$ |
| azure111s Member Since: 28 Apr 2011 Location: Wiltshire Posts: 71 |
I had that too!! EBC Green stuff were the worst pads I ever used, bar none! The build-up on my Elise's wheels was in the form of lumps rather than dust. Very difficult to shift too. A new set of pads lasted the journey from Wiltshire to Le Mans and then just one day on the Bugatti circuit. Had to change pads before the second day on track. Went back to Pagids and no probs there. Always thought I was the only one who didn't like EBC Greens. Nice to know I wasn't Back on-topic: I have never known wheels to suffer from 'permanent' early damage (new car) from brake dust like I have with LR wheels. This has included 18" on a 56 reg D3 S, 18" on an 08 reg D3 XS and the current FFRR 20" sparkle finish. Even Wonder Wheels struggled to clear the speckling on the D3 wheels, but not tried it on the FFRR yet. Did 75K miles in 2 years in an Audi Q7 and dust always shifted easily with normal cleaning. Wheels looked like new after all those miles in 2 years |
