Home > Maintenance & Mods (L322) > Color coded door handles and mirrors
Stryke
Hi there,
Can anyone recommend the best place for door handles and mirrors (color coded) for the '06 L322 model.
Thanks.
Post #75696 11th Aug 2011 1:50pm
Stryke
Are these any good: http://www.ebay.co.uk/itm/Java-Black-DOOR-...0226488129
A bit dubious as they are stick on.
Or am I better off going for the replacements, how easy is it to replace the door handles? do they simply clip off?
Thanks.
Post #75702 11th Aug 2011 2:02pm
pretlove
i have these and they look good when on but im sure you can get the oem handles cheap enough ....if you do a search there was a post about these before "RANGEISM WILL NOT BE TOLERATED"
Post #75704 11th Aug 2011 2:04pm
The door handles won't just clip on and off PITA , best just to get the stick on ones i have had mine on now for nearly two year Pressure wash tested and still stick on .
as long as you clean your old handles before you stick the other ones on ( thats if you go for the stick on ones ) ====================================
Post #75709 11th Aug 2011 2:10pm
they can be repainted, again there are threads on this subject..
Post #75710 11th Aug 2011 2:12pm
