Home > Maintenance & Mods (L405) > Aux belt length missing out Active Dynamics Pump
twintorque
United Kingdom 2016 Range Rover Autobiography SDV8 Siberian Silver
Active Dynamics pump has seized and jumped the belt, I’m away and would like to avoid having to get it recovered. Does anyone know what length belt can be used as a replacement missing out the active dynamics pump until I get home and the garage can replace it ? Much obliged if there’s an answer out there
Thanks in advance hopefully
Edit for brain fade and initially writing a/c compressor cause I’m a dipstick.
Post #692314 10th May 2024 7:29pm
GraemeS
Australia
Not that its of any help to you, years ago I had a belt to bypass the ACE pump on my TD5 D2 for remote area touring in case the ACE pump failed. Some trial and error in getting the length acceptable and trimming 1 rib from a wider belt was required, as none was available in an acceptable length and with the correct number of ribs. It worked even though it didn't wrap around the power steering pump pulley to the extent of the original belt although it wasn't ever put to use.
Post #692323 10th May 2024 9:47pm
