Home > Technical (L322) > L322 starting issue
L322madhatter
United Kingdom 2012 Range Rover Westminster 4.4 V8 Java Black
L322 starting issue
Hi all, I have an issue with my beloved L322 which I hope the community might be able to shed some light on.
For the past few months, I've been experiencing an intermittent issue when starting the car. I press ignition and it sometimes starts just fine, and other times it returns over 40 error messages. I have to turn off ignition and then back on again a few times until it lets me start it, but the engine light will stay on. It'll then randomly disappear after 4 or 5 starts.
Thought it was the battery at first so had it changed no luck and I've now got 2 batteries. Checked the alternator and all good, got the ECU checked and it came back all fine. Hell I even dropped it at a RR dealer and they couldn't figure out what is happening.
Wa starting to think it might be haunted as I was at loss as to what it could be, but I've recently noticed a pattern to it: if you press on the left of the start button, it is fine. And anywhere else it'll go bonkers. I wish I was kidding.
Bought a cheap £15 start/stop button on ebay to try and see whether that'd sort it out but I have the same issue. Should I try the pricey official RR one? Or is the issue somewhere else do you reckon?
Any thoughts and fresh pair of eyes greatly appreciated!
Post #693707 31st May 2024 9:03pm
GraemeS
Australia
The stop-start button has multiple contacts so perhaps the cheap replacement doesn't function adequately.
Check the power distribution boards located behind the battery for corrosion.
Post #693712 31st May 2024 10:25pm
Fox889
You could try a used genuine one & see if that helps….Gentleman of salvage I think are their name, try them? 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Alfa Romeo Giulietta
Austin A40 Farina MK2
1975 Morris Marina 1.8TC
1973 Honda CB250 K4
Post #693715 1st Jun 2024 7:25am
L322madhatter
Thank you both. I've checked the power distribution boards and no corrosion there (unfortunately?). Will keep an eye out for a genuine part
Post #693716 1st Jun 2024 7:30am
Weegie
Have a look at the earth to engine. John
GAP iiD BT-Sold
Post #693717 1st Jun 2024 8:00am
L322madhatter
Thanks for the suggestion. Where can I find the earth to engine?
Post #693718 1st Jun 2024 8:13am
Weegie
There is a main one under the right front wing behind the liner. Known to fail and give hassle, try a jump lead as an earth.
Mine was badly corroded and I had battery charging/starting problems. Replacement earth solved it. If it is that you can make up an earth strap with a length of battery cable. John
GAP iiD BT-Sold
Post #693721 1st Jun 2024 9:53am
L322madhatter
That's under the driver's side wheel arch. No obvious earth here unless I'm missing something? 2012 Java Black Westminster 4.4TDV8
Post #693723 1st Jun 2024 11:12am
L322madhatter
Post #693724 1st Jun 2024 11:13am
GraemeS
Australia
It's near the bottom corner of the radiator.
Post #693725 1st Jun 2024 11:59am
L322madhatter
Found it! Cable looks fine but where it connects to the engine/subframe is pretty crusty. Will spend some time on it this afternoon and update, fingers crossed 2012 Java Black Westminster 4.4TDV8
Post #693729 1st Jun 2024 1:22pm
L322madhatter
Cleaned everything over the weekend, so far 3 starts without faults (pressing any part of the button). Hoping it stays like this but otherwise might try and souce an official start/stop button. Thanks for the help! 2012 Java Black Westminster 4.4TDV8
Post #693806 3rd Jun 2024 8:10am
L322madhatter
Well, it was fun while it lasted... got about 10 starts without any fault but it's come back again. Any other components I should check or any other ideas as to what it could be? 2012 Java Black Westminster 4.4TDV8
Post #694264 11th Jun 2024 6:04pm
If the 10 starts was better than before then you are probably on the right track, check the earth lead for corrosion along it's length, does it crackle when you bend it? I've had them fracture before but work now and again as the outer plastic holds the two broken ends together, that lead was in an engine bay and had no earth with a hot engine as the two ends were pulled apart by the heat expanding the outer cable, when the engine cooled down it reconnected... took a lot of searching to find that one, personally I'd leave the one on there alone and fit another earth strap somewhere else... Thumbs Up Pete
Post #694269 11th Jun 2024 6:37pm
