![]() | Home > Technical (L322) > Wrong battery could this cause damage |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4349 ![]() ![]() ![]() |
Not sure but you definitely need an AGM 019 fitting asap Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
TomC-RRV8 Member Since: 18 Sep 2022 Location: Pangbourne Posts: 92 ![]() ![]() ![]() |
Thanks for that, are there any reconmendations for certain brands over others when it comes to the 019 AGM battery for the L322 4.4tdv8. Current
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3382 ![]() ![]() ![]() |
Take your pick
Thanks JayGee have purchased one so will fit it this week. Current
Paul H Member Since: 17 Oct 2023 Location: coventry Posts: 87 ![]() ![]() ![]() |
The car will give that warning by default after about 5 mins even with a perfect battery. You can't use the auxiliaries without the engine running for any length of time 2011 L322 Autobography - a lot of bells and some of the whistles...owner with no idea! |
