Home > Technical (L322) > Wrong battery could this cause damage
TomC-RRV8
United Kingdom 2012 Range Rover Vogue SE TDV8 Galway Green
I noticed the other day that the car was turning off the radio due to low power after not very long being switched off, when the car was not running. I have just checked the car and it has. Yuasa 5000 YBX5019 fitted by the previous owner. My car is a 2011 4.4tdv8
Now I note that this is not an AGM battery and am going to look to change it. Can it cause the car issues running the wrong type of battery. Sorry not my area of expertise. Current
2011 4.4TDV8 VSE Galway Green
1973 Rolls Royce Shadow 1 Brewster Green
1972 MGBGT Sage Green
Gone
2004 Discovery Landmark 2.5D
2003 Freelander TD4 SE
Post #694548 16th Jun 2024 2:47pm
DrRob
Not sure but you definitely need an AGM 019 fitting asap Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #694549 16th Jun 2024 3:04pm
TomC-RRV8
Thanks for that, are there any reconmendations for certain brands over others when it comes to the 019 AGM battery for the L322 4.4tdv8. Current
Gone
Post #694552 16th Jun 2024 3:42pm
JayGee
Take your pick
https://www.tayna.co.uk/car-batteries/types/019-agm/ 2012 TDV8 Vogue (L322)
Post #694553 16th Jun 2024 4:03pm
TomC-RRV8
Thanks JayGee have purchased one so will fit it this week. Current
Gone
Post #694555 16th Jun 2024 4:28pm
Paul H
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Stornoway Grey
Re: Wrong battery could this cause damage
The car will give that warning by default after about 5 mins even with a perfect battery. You can't use the auxiliaries without the engine running for any length of time 2011 L322 Autobography - a lot of bells and some of the whistles...owner with no idea!
Post #694557 16th Jun 2024 4:45pm
