Home > Technical (L322) > 2012 Westie Window Full Travel Intermittant
AndyRoo
Scotland 2012 Range Rover Westminster TDV8 Fuji White
Hi,
Here something that's started to annoy me recently, on odd trips the windows, any window, will not run it's full travel up when the switch is pressed to the second detent.
Down works fine every time, Up odd. For instance this mornings school run, front windows would not fully travel themselves up, had to hold the switch all the way, tried on all windows all the same, even from the individual door switches so it's not the driver's switch pack.
Went to Lidl, came home all fine working exactly as they should all good there and back. Got home, went out again an hour later, all good there and back.
Just went out to try again when moving the car, full travel up not working again.
No alerts, no errors, engine is running all the time so no power probs, mesaured on the GAP @ 14.2v, I've run through the reprogramme procedure a dozen times, no effect.
I know it's a nothing problem but driving me nuts with it's inconsitency, any ideas on what this might be ?
Andy Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #694773 20th Jun 2024 3:18pm
