![]() | Home > General > L322 4.4 RR Virgin questions - EAS, Memory seats, rear enter |
dan_uk_1984 Member Since: 12 Nov 2008 Location: Bude, Cornwall Posts: 4014 ![]() ![]() ![]() |
Congrats on your purchase! Get some pics up of your new beast!
pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865 ![]() ![]() ![]() |
welcome and pics please.....oh and of the ff |
RR8701 Member Since: 11 Aug 2011 Location: East Ayrshire Posts: 380 ![]() ![]() ![]() |
Hey. Thanks for the replies guys. I will defo post some pics up when I'm home tonight.
if you pull up and then press the button (turn knob) to put it in access hieght it will stop doing it once you open the door and will only continue to lower once the door is shut so maybe this is what gave you the impression it was doing it once he locked the car "RANGEISM WILL NOT BE TOLERATED"
PITA = Pain in the ass It's not possible to program the car to lower on lock/exit. For safety sake you may be off road and parked over a rock which would then puncture your fuel tank etc... As for the seat memory, there are several options, but I don't think the seat will move on exit - it can be programmed to move to pre-set upon door open, but then you'd need to manually move it back fwd every time you get in the car etc. The S/wheel should move up and in when you take the key out of the ign so it gets out of your way.... The seat doesn't really move fast enough to be of any benefit when exiting. D |
Hey All,
wackyjim Member Since: 11 Aug 2010 Location: Brigadoon Posts: 2014 ![]() ![]() ![]() |
Not sure about 2004 model but my seat moves back and steering wheel rises up the minute I open the door to leave the car and when I go back into the car and switch ignition on everything goes back to preset position. |
if you want to use the img button to post pics you copy the url of the pic and paste it after you click the img button then again at the end of the url you click the img button again if you havnt got your pics saved on a website then you need to save them to your gallery first
