![]() | Home > Technical (L322) > Seized engines in 2010-2012 4.4 TDV8 |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3382 ![]() ![]() ![]() |
TDV8 on the L322 or SDV8 on the L405? 2012 TDV8 Vogue (L322) |
lodelanelad Member Since: 14 Dec 2021 Location: London Posts: 62 ![]() ![]() ![]() |
Yes the TDV8 on the L322 |
It's not a common issue on the L322 at all - very rare infact. Nothing to worry about. 2012 TDV8 Vogue (L322) |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 850 ![]() ![]() |
120k miles on mine - i have no concerns about seizure.
Where can you get low SAPS 10w-40? 2012 TDV8 Vogue (L322) |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 793 ![]() ![]() |
My guess would be that the most common cause would be poor or none of existent servicing.
JayGee
That 5w-40 is a good find |
That oil is C3 so mid SAPS and not low SAPS. Not sure why Opie are calling it low SAPS. 2012 TDV8 Vogue (L322) |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3817 ![]() ![]() |
I’m on my 4th V8 diesel - not one issue with any of them. I’ve had 17 RR’s - the V8 diesel is the least of you worries ! 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
Fla Member Since: 26 Nov 2023 Location: South west Posts: 192 ![]() ![]() ![]() |
I'm still convinced some of these failures are factory related, maybe just a part with a slight tolerance difference used or installed slightly off or as mentioned poor service. Though I have heard of full main dealer serviced cars blowing up with crank failure I haven't read that about the L322 or L405 yet.
