Home > Technical (L322) > 4.4 TDV8 - Cabin heating not working/header tank pressure
lodelanelad
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Santorini Black
Does the cabin failing to heat properly whilst the header tank building up excess pressure always means a head gasket failure? Any idea what else would cause both symptoms? Thanks
Post #695260 29th Jun 2024 4:30pm
Dutchgit
Germany 2008 Range Rover Vogue TDV8 Stornoway Grey
If it has lost coolant and there's an airlock in the system to the heater you won't have heat.
Very possible with a over pressured system because of a leaking head gasket.
Post #695261 29th Jun 2024 5:05pm
lodelanelad
Thank you
Post #695263 29th Jun 2024 5:19pm
