![]() | Home > Maintenance & Mods (L322) > Anyone got experience with making/using goodrich brake hose? |
Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261 ![]() ![]() ![]() |
Your main problem as I see it (and I have Goodridge hoses on my 110) is that one length of pipe means replacing nearly all the brake fluid should you have to replace a calliper as the Goodridge hoses cannot be clamped.
Just avoid. There has been problems in some where they chamfer on something or the braid breaks and you get bulges. Just stick to oe unless your racing it |
Lloyd Barnes Member Since: 21 Apr 2011 Location: Shrewsbury Posts: 181 ![]() ![]() ![]() |
I've made them up for hydraulic clutch lines on the cobra before. Reasonably easy enough to do although they are eye wateringly expensive!!
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1511 ![]() ![]() |
thanks for the advice chaps. Think i'll rule out goodrich at the moment. V8 or else ... |
