![]() | Home > Technical (L322) > 4.4 tdV8. Engine Management Light . |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3864 ![]() ![]() ![]() |
B.B. went for its annual MOT yesterday.
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3308 ![]() ![]() ![]() |
Anything showing on a GAP IID scan inc when pending faults are enabled? 2012 TDV8 Vogue (L322) |
Only PO40D-00(2F) which has been showing for many years.
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2742 ![]() ![]() |
Presumably the tester didn't record the code before clearing it. |
I am not sure if he actually “manually “ cleared it or if it just cleared itself, but he just said that it came on for an instant and he couldn’t see any cause or reason.
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1400 ![]() ![]() |
If it came up then cleared most likely misfire detected for a time.
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3270 ![]() ![]() ![]() |
EGR sensor code which could even be a bit of dirt on the sensor whhich has then been dislodged? John
Thanks for all your help, I will see how it goes , at least he didn’t hesitate to do a full retest .
matthews Member Since: 09 Aug 2016 Location: Leeds Posts: 111 ![]() ![]() ![]() |
If the tester turned the engine off (not running but ig on to enable steering to be turned )whilst it was being tested and then put front end up in air and did lock to lock whilst looking at various suspension joints it will bring on EML when restarted as it throws steering angle sensor out of calibration , restart and lock to lock a couple of times and it'll sort itself out , also happens on D4's and prob RRS, make sure tester keeps engine running whilst moving steering on test (found this out a few years ago when it happened to me when having one of my customers cars tested ) |
Matthew’s,
Easy way to show this is to do just that , jack front end up , ignition on and lock to lock it a couple of times by pushing on wheels (as would happen in test ) , , pop it back on floor and start it up , eml will be on and fault code will be steering angle sensor , lock to lock it with engine running a couple of times and it will clear after recalibrating , can't believe your tester failed it on this and then passed it after clearing fault but each tester has there own foibles .You would not believe the argument I had on Friday with a temp tester and a Defender ABS light , would not accept that self test function and light going out requires vehicle moving at 5kmh. |
