Home > Technical (L322) > Main beam not working, flash does??? Solved
FJ12Jagmen
United Kingdom 2007 Range Rover Vogue TDV8 Santorini Black
As above. It's a bit puzzling because I was using the main beam extensively on a night run from Edinburgh to Essex on Monday night. Wednesday morning it passed the MOT with no issues. Thursday night no main beam but flash worked perfectly.
GAP IID does not show any relevant faults. Checked through the CCF files and could not see anything odd.
A search brought up one similar post from a 2004 FF where the Light Control Module had sufferred water damage. The owner sent it for repair and solved the issue. The LCM in that vehicle was located behind the panel next to the accellerator. Is it the same in my 2008 MY?
I had the knee bolster and column surrounds off 2 months ago. Did not see any water ingress or signs of corrosion. All connectors looked good.
Any ideas? 2007 3.6 TDV8
1979 Mini Special
1988 Yamaha FJ1200
!952 BSA Gold Flash
Post #695676 7th Jul 2024 12:12am
FJ12Jagmen
What a plum. My MOT man had switched off the lights. Because I have daylight running turned on I didn't notice. Simply turning the switch to auto solved it. Embarassed 2007 3.6 TDV8
1979 Mini Special
1988 Yamaha FJ1200
!952 BSA Gold Flash
Post #695757 8th Jul 2024 2:15pm
mjdronfield
Ah. Got there in the end. Easy done if you don’t notice the rears were off.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #695763 8th Jul 2024 3:04pm
