Home > Maintenance & Mods (L405) > Would you change oil ?
Tiny Timmy
I have a 2013 L405 , 73k fsh , I now only do about 5k a year.
should i be changing the engine oil every 6 months ?
I only do short journeys generally with the occasional long run.
TT
Post #696124 13th Jul 2024 5:08pm
ReggieMac
United Kingdom 2019 Range Rover Autobiography SDV8 Loire Blue
Short answer, yes! Due to the short trips you are at much greater risk of oil dilution. I too now only do approx 5k miles per year and shorter trips and I personally change the oil and at least once between annual service, so easy to do yourself, even if you are not very handy with the spanners, and relatively cheap. _______________________________________________
2019 4.4 V8 Diesel Range Rover Autobiography, Byron Blue
Post #696128 13th Jul 2024 5:28pm
Tiny Timmy
Thanks Reggie, what oil / filter do you use ?
Post #696132 13th Jul 2024 8:13pm
ReggieMac
I always use a Mahle brand filter and 5W 30 C1 engine oil although there could be some debate amongst some to be using 5W 40 for higher mileage engines. Personally I stick with the 5W 30 C1. If search this site you will find many, many posts about this and where to get oil & filter from. Thumbs Up _______________________________________________
Post #696179 14th Jul 2024 5:28pm
Tiny Timmy
Excellent thanks Thumbs Up
Post #696183 14th Jul 2024 5:43pm
Seatown
Scotland 2013 Range Rover Vogue SE SDV8 Firenze Red
As recommended by others on here I've been using this since I got my L405.
Good value and a 20L drum will do two changes. Great service from S&A, especially delivery to Scotland which is often an issue for other suppliers.
https://www.smithandallan.com/product/smit...e-oil-4127
Post #696184 14th Jul 2024 5:46pm
Tiny Timmy
Great Seatown thanks, I was thinking that was a good way to go Thumbs Up TT
Post #696186 14th Jul 2024 5:51pm
supershuttle
I'm like Timmy, actually may do a few more miles but lots of short journeys so there's a risk of oil dilution (a very small risk IMHO). I get my car serviced with an Indie in November and I do a quick oil change at the halfway point. Just done it in fact, using the draper pump and oil from Smith and Allen and the filter from eBay actually. I might just get the whole lot from Opie next time as it's simpler. An oil change is cheaper than a tank of diesel so it's pretty much a "no brainer" as they say. Geoff
Post #696195 14th Jul 2024 10:13pm
kevinp
Defo change the oil. Just done mine and got 10 litres out!
I do mainly short journeys to.
Post #696198 14th Jul 2024 10:45pm
Tiny Timmy
Thanks everybody.
I've never had trouble but thinking best to cover myself, prevention is better than cure as they say. Smile
Post #696203 15th Jul 2024 6:43am
