![]() | Home > Technical (L322) > Hard start from cold |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1404 ![]() ![]() |
Try resetting engine adaptations
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2250 ![]() ![]() ![]() |
Forgot to say tried that multiple times to no avail - the problem was worse after running lpg which led me to disconnecting it but still having issues Current stable:
Hey Dan
Yea - I did fix it and it was the same as it was last year… a bad lpg injector… it sticks open when the car is off and fills the manifold with gas so needs the cranking to clear the gas.
Cheers Dan, maybe the same for me, I've isolated the gas side of things to eliminate that possibility, I'll see how it goes next few days, it's only on hot days so the under bonnet high morning temperature isn't helping when it's sitting in the sun , soon find out whether it's lpg side or petrol side....
34 degrees and started first crank, just need to determine which lpg injector/s passing now
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 1039 ![]() ![]() |
If you want to stop those lpg injectors from sticking give them a good shot of wd40 once in a while. |
