Home > Technical (L322) > L322 Front Seat Backrest Panel Removal
steve k
United Kingdom 2003 Range Rover HSE Td6 Giverny Green
2003 HSE with heated but non vented seats.
I'm trying to remove the panel on the back of the driver's seat backrest/squab and running into issues. I know from past experience that brute force and determination will likely result in damage hence seeking some guidance on whether I just need a bit more determination and a Tad more force.
Lots of videos around but they are all for either later or Vogue seats with a different construction to my HSE early model
RAVE makes it pretty simple and it appears to replicate my seat design but the panel appears bonded to the side bolsters as I can get a trim tool between the panel and side to try and release the side clips on the panel. The bottom of the panel seems pretty much locked in place as well. Essentially nothing seems to budge..
Do I need to unclip the squab that seems clipped along the bottom of the backrest as noted in picture below? Will the side of the back panel need brute force to be pushed towards the front of the car whilst being squeezed in from the bolster or is there something else I'm missing???
 Current: 2003 TD6 HSE
2004 Vogue SE 4.4
Previous: 1993 Classic 3.9
Post #696792 24th Jul 2024 11:12am
Marcus76
2006 Range Rover HSE 4.4 V8 Alaska White
Hello,
In the second picture you have that button, pull the leather backwards step by step around the plastic piece. It’s only pushed in. And as far I can remember there is one bolt or a screw on every side inside the seat . Excuse my bad English.
Marcus
Post #696796 24th Jul 2024 11:40am
steve k
Thank You Marcus - Your English is very good. If you are referring to the plastic strip it won't pull out rearwards - even with a pair of grippers it was starting to tear away from the plastic strip. I have now got it removed - its pushed in over 3 25mm wide grippers hence not wanting to come out..
The buttons shown un-clipped are the only two that RAVE references (after removing staples and folding back material which my seat does not have)
The plastic ledge appears to be part of the back panel I'm trying to remove, hence needing to un-clip the strip.
The back rest is still stuck firm though Current: 2003 TD6 HSE
2004 Vogue SE 4.4
Post #696805 24th Jul 2024 12:30pm
Marcus76
Hello I took pictures of my spare seat.
To remove the back you also have to remove the armrest
First picture shows the „bolts“ and the second shows where the leather is pushed in.
Marcus
Post #696809 24th Jul 2024 1:16pm
Marcus76
Blue arrow isotherm hole from the armrest , yellow is where you have to pull out the leather
Blue is my so called bolt (pull it down )
Yellow is the hole where your button used to be.
Marcus
Post #696815 24th Jul 2024 1:43pm
steve k
Das Gelingen (success) Thumbs Up
Just as You said Marcus - I would never have figured this out, well maybe after a few days of cursing..
For the benefit of other owners still running early HSE models pictures below:
Note: the arm rest has a shroud on the spindle that covers the Torx grub screw but its not a full enclosure type - with persuasion it can be rotated to expose the grub screw.
I'm gonna call this a 'wrap' all thanks to Marcus - I owe you a Beer Thumbs Up
2004 Vogue SE 4.4
Post #696816 24th Jul 2024 1:59pm
