Home > Technical (L405) > Light Judder from standstill - Rear active anti roll bar
garyRR
Ok, so my light judder has tentatively been diagnosed as my rear anti roll bar. There is a misting of oil on the reservoir on the bar (but not the pipes). I will inspect the o-rings on the feed hoses more closely once I've cleaned it up.
The mechanic recommended performing diff fluid changes anyway. Having checked my history, they were last done at 60,000 miles, so definitely due regardless.
Are there any seal repair kits for the roll bars or are they a one shot job?
Also can anybody point me to which is the active anti roll bar reservoir in the engine bay, so that I can keep an eye on the fluid level? It looks like it might be shared with the power steering? 2015 Range Rover Autobiography 4.4 SDV8
Post #697082 29th Jul 2024 4:58pm
Reservoir for ARB's is on the right side of the engine as you look at it with the bonnet open, it's a clear plastic bottle and a few have mistaken it for the coolant.. it's about half way back in the engine bay...
Picture of S/C but the SDV8 is the same... Pete
Post #697083 29th Jul 2024 5:21pm
garyRR
Many thanks. Checked the reservoir and fluid level is normal and still translucent. 2015 Range Rover Autobiography 4.4 SDV8
Post #697085 29th Jul 2024 5:41pm
knwatkins
Re: Light Judder from standstill - Rear active anti roll bar
Power steering is electric on the L405, not hydraulic ie. no fluid. Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #697107 29th Jul 2024 10:05pm
