Home > Maintenance & Mods (L405) > Lower rear hatch motor does not fully open/close
bdd123
United States 2017 Range Rover Autobiography 5.0 SC V8 Aintree Green
Without any warning.
Open with exterior "handle", top opens fine. Press button on lower and it just unlatches, no movement by motor.
Try to close both via top button and nothing happens.
Close lower manually and soft close works and latches.
Top then closes automatically.
Any advice?
I looked at codes and then cleared them, I will have to check them again tomorrow.
Any ideas? I did not see anything obstructing it.
Throwing code B144B-15 - Anti-Pinch Hardwired signal input - circuit short to battery or open (2B).
It threw a bunch of codes first time I read them, but after clearing them, this one persists. Current: 2017 L405 ATB, 2016 LR4 SE
Past: 2001 RRR H&H, 1993 RRC SE, 1989 RRC, 1990 RRC, 1995-97-98 D1
Post #697146 30th Jul 2024 4:11pm
The anti-pinch sensor is on the side of the lower tailgate - it comes as a complete unit that is the plastic on the side of the lower tailgate.
I had a similar issue - the lower tailgate would open, but not power close. If I pushed it manually the top part worked just fine.
Mine eventually turned out to be a broken wire on the tailgate wiring loom as well as a faulty anti-pinch sensor.
https://www.fullfatrr.com/forum/topic47843.html
Post #697149 30th Jul 2024 4:23pm
