Home > Technical (L322) > Reduced Engine Performance
dan_uk_1984
Now that im a member of the sc club, my membership wouldn't be complete unless i was broken down on the M4 awaiting recovery!
While i accept this is all part of ownership, couldn't it have done it at a slightly less inconvenient time/place?
I'm guessing it's the auxiliary coolant pump to the sc. Hopefully no damage done...
Post #76537 17th Aug 2011 12:33am
pretlove
i hope you get it sorted and it turns out to be something simple and cheap Thumbs Up "RANGEISM WILL NOT BE TOLERATED"
Post #76538 17th Aug 2011 12:59am
dan_uk_1984
I'll see you in ASDA!
Post #76539 17th Aug 2011 1:01am
pretlove
Laughing "RANGEISM WILL NOT BE TOLERATED"
Post #76540 17th Aug 2011 1:01am
Mikeyjd
Wales 2003 Range Rover SE Td6 Zambezi Silver
This reminds me, I really must sort out breakdown cover as soon as I can. Hope you get home soon. No longer FF owner but still interested. Present car Jaguar XE
Previous car Td6 SE
Previous LR- Disco 300TDi Auto
Post #76542 17th Aug 2011 1:02am
dan_uk_1984
The RAC suck. I'm still here!
Shame no analogue tv signal!
Post #76545 17th Aug 2011 1:37am
pretlove
have they showed up yet "RANGEISM WILL NOT BE TOLERATED"
Post #76546 17th Aug 2011 2:04am
Bob the B
United Kingdom 2004 Range Rover Vogue Td6 Santorini Black
Dan
Don't worry ur not missing anything on the tv and Im in the house watching ALL THE CHANNELS.
Just Censored on as usual Yawn
Hope ur sorted soon Thumbs Up
Post #76548 17th Aug 2011 2:19am
dan_uk_1984
Just got home. drove off transporter perfectly with no messages. MIL remained on. Neither Rover all comms or my obdc reader want to read the code. 99% sure its the auxiliary coolant pump.
Post #76550 17th Aug 2011 3:44am
AMD
Dan, Speak to Wiggs and get the Digital Tuner fitted. Then you can watch QVC on the hard shoulder next time.... Current MY2020
Gone: 1 x L405 and 2 x L322's
Post #76558 17th Aug 2011 10:29am
dan_uk_1984
Yawn.
Booked into my indy, he ordered the Aux coolant pump today and will fit it tomorrow.
Then I should be back supercharging everywhere.
Post #76569 17th Aug 2011 3:31pm
JustinP
Hi Dan,
What symptoms indicate it's the auxiliary coolant pump?
Cheers
Justin
Post #76573 17th Aug 2011 4:48pm
dan_uk_1984
JustinP wrote:
Hi Dan,
Cheers
Justin
"Reduced Engine Performance" message on a SC RR is 99% caused by this.
A large proportion of 2005-2007 SC RR's had the electric coolant pump wired the wrong way round, being a centrifugal pump it doesn't do it any favours running back-wards so leads to early failure.
You can test your aux coolant pump by activating the "Rest Heating" function - Outside temp less than 15C, after turning off and taking key out of ign press "max ac", make sure after a few minutes the air coming out the vents is hot. If it's cool/cold then the pump doesn't work/is wired incorrectly.
The fix is to correct the wiring (if your car is affected) and replace the pump if wired back-wards (even if it still works, it wont last much longer)
Post #76577 17th Aug 2011 5:20pm
Ludzy
United Kingdom 2005 Range Rover Vogue SE Supercharged Zambezi Silver
As mentioned in many of my posts this has happened to me. Fairly simply job to replace when I did mine and no problems since. Just a shame I had. To find out myself as th garages didn't have a clue.
Cheers Ex FFRR 4.2 Supercharged
www.thecarpetfitter.co.uk
Post #76597 17th Aug 2011 8:49pm
dan_uk_1984
Cheers
It's your posts that helped guide me to a resolution whilst sat on the M4, so thanks for taking the time to put the info on the forum.
As long as this is resolved in mine tomorrow I might drop you a PM to arrange some sort of writeup for the WiKi if that's OK? It would be good to get the info in one place...
Thanks,
Dan
Post #76603 17th Aug 2011 9:45pm
