![]() | Home > Maintenance & Mods (L405) > Front brakes!! Wow! |
oggy Member Since: 09 Sep 2020 Location: padstow cornwall Posts: 397 ![]() ![]() ![]() |
much the same as the rears go on you tube i am sure a video which will explain how step by step new vehicle purchase
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1238 ![]() ![]() ![]() |
This should help. Rimmer Brothers videos are very good. |
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 491 ![]() ![]() ![]() |
They’re as easy to change as any other pads / discs, nothing special about the callipers or pins.
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 672 ![]() ![]() |
The fronts are quite time consuming, mainly because it takes a while to work the pins out and then clean up any corrosion. But otherwise they are easy to work on |
zenman63 Member Since: 14 Nov 2021 Location: Warwickshire Posts: 257 ![]() ![]() ![]() |
I have just done mine all round, fitted Jurid pads, they make the oem pads, it’s printed on the back of the Land Rover pads.
Buz1500 Member Since: 05 Sep 2011 Location: Cumbria Posts: 369 ![]() ![]() ![]() |
Land Rover quote £862.05 for replacement of front discs and pads on their website. 2019 L405 SDV8 Autobiography
