Home > Technical (L322) > Seeking CANBUS experts
Page 3 of 3 <123
btbtbtbt318
Australia 2006 Range Rover Vogue 4.2 SC V8 Zambezi Silver
Hi Mikey. Very interesting.
When I bought the car, it had already had work done to try to fix the issues, being the replacement of the ABS module. The previous owner and his LR specialist had determined that the original module was the cause of the fault (I am not convinced).
The replacement module, which was in the car when I got it, is an SRB 500 174. However, this module throws the error incorrectly reading the brake switch circuits. This module is in near pristine condition which aligns with it being a new old stock replacement as I was told.
The car also came with its "original" module, not installed. This module is an SRB 500 164. The wear and tear and dirt colouration on this module matches the rest of the engine bay so I am assuming that there has been no mix up and the car did indeed live with that module for most of its life.
The SRB 500 164 that I purchased second hand and brought in from the US as an equivalent to the module I believe is original to the car was apparently mated to a 4.4 (presumably BMW) petrol. Hard to know for sure. The build date on this new module is 21/12/05, which is why I picked it as it's reasonably close to the build date of the car.
I am conscious that the build date being May 2006, that there is a good chance that this thing might be a parts bin special during the transition from BMW to Ford. Hopefully not one with unique programming of old modules which can never be recreated... Laughing
If it helps, my VIN is SALLMAM336A234213 (frustratingly just a few thousand earlier than the 2006 wiring diagrams).
Thanks for your continued attention and patience.
Post #711358 8th Feb 2025 11:09am
Mikey
SRB000174 is the correct part number for the ABS block, according to your VIN...
Post #711398 8th Feb 2025 9:10pm
knares
Australia 2005 Range Rover Vogue 4.4 V8 Zambezi Silver
following RR 2005 4.4 petrol
Any spelling mistakes are the fault of spellchecker
Previous MG J2, CITROEN light 15 x 2 gone unfortunately
Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar
Post #711413 9th Feb 2025 6:05am
knares
would you mind explaining to me why you are concentrating on the part numbers of the hydraulic component, rather than the electrical part number of the ABS unit RR 2005 4.4 petrol
Post #711432 9th Feb 2025 3:30pm
Page 3 of 3 <123
