Home > Technical (L322) > Update to air suspension problem
tj196443
United Kingdom 2010 Range Rover Vogue TDV8 Zermatt Silver
Hi, as previously posted having an issue with the car dropping at the front when parked up.
Took the front nearside wheel off first as I suspected this to be the dodgy sensor and as I started to jack the car up the airbag started to release the air very fast. Cleaned up the sensor but know I will need to cut off the old corroded bolt at the bottom which was basically just rust to change the sensor.
Started the car which lifted straight away and 4x4 screen and gap showing incorrect data from ride height control, cleared fault which hasn't come back but car has dropped at the front again.
I'm assuming the airbags dont deflate themselves when the car is lifted and its got a dodgy sensor, never known the car to release air when jacking but hoping others know better and it is indeed time for a new airbag to the wheel.
Post #698297 18th Aug 2024 12:52pm
JayGee
If the air is releasing from the bag itself then it’s leaking as the suspension air release is on the compressor in the boot. 2012 TDV8 Vogue (L322)
Post #698304 18th Aug 2024 3:32pm
tj196443
Thanks for the reply, I just checked with soapy water and its coming out at the bottom of the airbag just under the folded part.
Post #698313 18th Aug 2024 4:34pm
Alinton
Ireland 2011 Range Rover Vogue TDV8 Zambezi Silver
That's always the first thing to check - its the most common failure.
Post #698315 18th Aug 2024 5:09pm
tj196443
Looking at the difference between swapping the air bag compared to the whole strut I’m thinking of just changing the whole strut as it’s not a massive job. I have the Gap to calibrate the suspension and don’t see any big issues changing it myself and saving on garage labour costs.
Post #698322 18th Aug 2024 5:52pm
JMC
Save yourself from future grief and do both fronts at the same time. Wink The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #698347 18th Aug 2024 9:27pm
