![]() | Home > Maintenance & Mods (L322) > AC hoses connected to the compressor are stuck |
Steveg Member Since: 06 Apr 2024 Location: Norfolk Posts: 70 ![]() ![]() ![]() |
If the hose allows, try rotating it by twisting it backwards and forwards until you get movement, then lift at the same time. |
blueRR2006 Member Since: 13 Jan 2014 Location: Chicago, IL Posts: 38 ![]() ![]() ![]() |
Yes that worked, along with lifting up with a slightly angeled interior panel wrench. Thank you!!!!
