![]() | Home > Off Topic > New driveway solutions? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35857 ![]() ![]() |
theres a couple around the corner from me that had coloured tarmac laid for a cost of £7k....unfortunately trams lines appeared shortly after because as in your case they parked in the same place ..
Alex1976 Member Since: 22 Mar 2023 Location: Bucks Posts: 196 ![]() ![]() ![]() |
I had my worn out tarmac replaced with Cotswold stone (20mm chipping) and it is proving to be a good choice after 2 years. It looks beautiful, porous for rain discharge, doesn’t spread like gravel as it is angular and ‘locks in’. Really pleased with it.
Arch Stanton Member Since: 26 Apr 2012 Location: chavshire Posts: 536 ![]() ![]() |
that is great info thanks Stan, is this the composite stuff? Onto my 2nd FFRR, this time an L405 5.0L SC AB in SVO Palette black. |
thanks Alex, is yours a resin bonded stone? that sounds very interesting, dont suppose you have a picture you can post? Onto my 2nd FFRR, this time an L405 5.0L SC AB in SVO Palette black. |
i dont know the type of stuff they put down but it did look very nice when new and not like regular tarmac. ... - .- -.
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3986 ![]() ![]() ![]() |
I wouldn’t touch any form of tarmac. Unless it’s machine laid it’s never truly even so that every time it rains you get puddles. I have shingle which always looks the same whatever you do to it. I do however miss an area of hard standing for car maintenance etc. |
maybe a slab of coloured concrete [if thats a thing] ... - .- -.
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1238 ![]() ![]() ![]() |
My brother had a 'red tarmac' laid on his driveway a few years back and it still looks good with no tramlines.
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1198 ![]() ![]() ![]() |
If you are looking at resin bound you may want to consider Addagrip.
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8126 ![]() ![]() ![]() |
Yep - it's all about the preparation & base layers, not what's on top..... |
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 701 ![]() ![]() ![]() |
I have small pebbles / gravel, it's the cheapest option but it does tramline so I rake it regularly, takes about 5 mins and it's good as new. Anything else will sag and crack over time, it's inevitable, however, some can easily be relevelled and drain naturally, asphalt & concrete cannot be invisibly repaired and do not drain well.
MPx Member Since: 29 Jul 2011 Location: South Somerset Posts: 641 ![]() ![]() ![]() |
We have a significant area of 20mm Basalt chippings which I've put in the plastic honeycombe structure you may have come across. They hold the gravel in place (despite slopes) and it doesn't tram line as long a you only go a few mm deep on top of the plastic grid. Only maint I've needed to do in a couple of years or so is add a little more gravel where it had settled and you could start to see the grid edges - looks better when they're properly buried, but go too deep and you get tram lines.
Is that a cheaky M100 poking it's bum out there ? Very nice toy.
Oh yes! Been a Lotus fan boy for more years than I care to remember. Doesn't usually live there - normally tucked up in the barn...
