Home > Technical (L322) > Faults using IDD Tool G3 with 2005 L322 HSE - 'real' ones?
invisible999
United States 2005 Range Rover HSE 4.4 V8 Chawton White
After getting and registering my IDD Tool I did code reading and it came up with following
Using IIDTool BT V4.0 B3998
AAM-Audio Amplifier
B1A03-13 (2F) Speaker 3 circuit - General electrical failure - circuit open
( at 2141416 mi )
- Test Failed
- Test Failed This Monitoring Cycle
- Confirmed
- Test Failed Since Last Clear
ACM-Audio System
U1A03-62 (2B) Vehicle configuration parameter - Algorithm based failure - signal compare failure
( at 2141416 mi )
- Test Failed
- Confirmed
U2003-86 (28) Fibre optic communication bus - Bus signal/message failure - signal is invalid
( at 2141416 mi )
- Confirmed
ATC-Heat / Cool
0x30 Air quality sensor line fault
CDP-CD Player
U1A03-62 (50) Vehicle configuration parameter - Algorithm based failure - signal compare failure
- Test Not Completed
- Test Not Completed This Monitoring Cycle
ECM-Engine (ME7.2)
0x43E P0000-Multiple misfire fault
0x435 P0000-Misfire detected cylinder 8
FEM-Navigation
B110E-25 (40) Tailgate double locking motor - General signal failure - signal shape/waveform failure
( at 0 mi )
B110F-25 (40) Heart beat sensor - General signal failure - signal shape/waveform failure
B1110-25 (40) Air suspension delay power - General signal failure - signal shape/waveform failure
B1A89-13 (40) Satellite antenna - General electrical failure - circuit open
B1D62-87 (40) Sub-module 'B' - Bus signal/message failure - missing a message
B1D62-49 (40) Sub-module 'B' - System internal failure - internal electronic failure
IP-Instrument Pack
0xBD EBV function fault received from ABS ECU
PATS-AntiTheft
0x33 Key 3 - Random code tolerance increased
Before doing ANYTHING, I have couple of questions.
First - which of these codes are 'real'? Because I was reading that this error - BV function fault received from ABS ECU should be ignored.
Secondly - what the heck with 2141416 mi - 2.1 million! miles? Where this came from
Thirdly - how do I isolate/figure out what is going on? I also have ALL COMMS III and nothing except these misfire errors show up there:
MKIII Communications Performed by RSWsolutions - All Comms Software.
L322 Air Suspension Module Query Results: Performed on 7/28/2024 7:56:28 PM
Air Suspension System Fault Reading Complete...
0x32   0x0032   CAN bus Fault.
L322 ECM_M62 Module Query Results: Performed on 7/28/2024 7:56:49 PM
Petrol Engine Management Fault Reading Complete...
0x135   P0308   Misfire detected cylinder 8.
0x136   P0306   Misfire detected cylinder 6.
0x13E   P1300   Multiple misfire fault.
0x19A   P0277   Cylinder 6 injection circuit fault.
L322 Instrument Cluster Module Query Results: Performed on 7/28/2024 8:02:10 PM
Instrument Panel Module Fault Reading Complete...
0xBD   0x00BD   EBV function fault received from ABS ECU.
Post #699579 5th Sep 2024 9:03pm
invisible999
Update on this matter. Apparently the plug right above the DVD reader where Navigadion DVD is was unplugged. I plugged it back, cleared errors and now only see following ones after clearing errors
ACM-Audio System
U1A03-62 (2B) Vehicle configuration parameter - [b]Algorithm based failure[/b] - signal compare failure
( at 2141416 mi )
Test Failed
Confirmed
IP-Instrument Pack
ATC-Heat / Cool
The first one is still strange, with remaining 2.1 millon miles. But what is the above bolded - anyone knows?
The second one should be ignored based on my search.
Which leaves us with the third one. I looked at sensor and it is the one on photo below. I tried to clean it - it was full with small dust type thing on the left intake side, put it back but no changes.
What are replacement oem/aftermarket part numbers for this?
Post #699649 6th Sep 2024 10:29pm
pcourtney
perhaps a little searching on the forum first would be a good idea Sir
https://www.fullfatrr.com/forum/topic28100.html?highlight=0x30
Post #699663 7th Sep 2024 8:23am
invisible999
Question - if the part number is the same 6411-8 391 470 will it be interchangeble?
I ordered this item off ebay
https://www.ebay.com/itm/266921777858
Post #699725 7th Sep 2024 9:05pm
pcourtney
I don't think so, you want the part that comes from the BMW E53 ( which was the BMW X5 series and the years from 1999 to 2006 )
but you might be OK, after all it is a simple part sold in lots of BMW's of the time - good luck Smile
Post #699731 7th Sep 2024 10:04pm
invisible999
Update on this matter - bought this item on Ebay
After the replacement - I don't see error on GAP ID Tool any more.
Post #700136 15th Sep 2024 6:45am
