![]() | Home > Technical (L322) > Yep: another self inflicted LED "upgrade" help me |
tspd Member Since: 13 May 2024 Location: London Posts: 70 ![]() ![]() ![]() |
Hi all,
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7994 ![]() ![]() ![]() |
I believe that the car checks bulbs when ignition is turned on, hence the pulses you are seeing initially. Disabling checks will stop that but obviously you won’t know if a bulb has failed without looking yourself.
SeldomSeenKid Member Since: 24 Jan 2024 Location: Glasgow Posts: 85 ![]() ![]() ![]() |
RE the puddle lights.
Thanks all, will give it a try and report back here.
This has been posted elsewhere but mentioning here in case someone else sees for the approach lights (wing mirror) LEDs.
Multiple different indicator bulbs front and back replaced and they still hyper flash x5 on start up (only when triggered). After that they are fine, perhaps a tad faster than original but the trade off is worth it. Once I have budget for an IID I'll see if that helps. As it stands just the H7 main beam to replace now.
