Home > Technical (L322) > 3.6 tdv8 Mystery footwell switch?
Happydaze
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
I'll apologise in advance if this proves to be a numpty question but I have looked in the owners manual to no avail and couldn't think of how I might search for it here.
2007 tdv8.
I've just replaced to FSR thingy to get the heater fan working properly. I doing so I had to remove the panel above the pedals in the footwell.
Fitted to this panel are a footwell light, obd port and a switch. I've not seen any of these items mentioned on any other FSR replacement how to's, but they're not a problem, but disconnecting the obd is a bit tricky.
But what does the switch do? It's labelled Ford so it's obviously a Ford era item, not BMW.
I've never seen it before, obviously never used it either, but it must have some purpose. I hope I've not been missing out on an amazing feature!
Anyone know?
Chris
Post #700478 20th Sep 2024 1:59pm
Scouse Exile
The answer is here, I found it too and wondered the same thing:
https://www.fullfatrr.com/forum/topic52385...ell+switch
Jon
Post #700491 20th Sep 2024 3:49pm
Happydaze
Thanks for the prompt response! So, it doesn't really do anything of much use then! Dissappointing!! Ha!
Chris
Post #700499 20th Sep 2024 4:37pm
