![]() | Home > In Car Electronics (L405) > SOS SYSTEM NOT AVAILABLE |
MPx Member Since: 29 Jul 2011 Location: South Somerset Posts: 632 ![]() ![]() ![]() |
Has your SIM expired or run out of data? Mike - MPx
JackRegan Member Since: 20 Oct 2012 Location: Wirral Posts: 258 ![]() ![]() |
I got the same message on my 2016, it turned out to be the telematics battery had gone flat and needed replacing as it was no longer taking a charge.
Spridget Member Since: 09 Dec 2023 Location: Northumberland Posts: 199 ![]() ![]() ![]() |
The same fault plus 'TPMS unavailable' on mine turned out to be a dash cam that I had fitted. After much fiddling about with camera positions etc the SOS went away so now I have the choice of dash cam or TPMS but not both at the same time.
Fifth Horseman Member Since: 04 Jul 2016 Location: Lanarkshire Posts: 235 ![]() ![]() |
It's possible that there may be water ingress to the antenna or the battery failing causing this but really needs the fault codes read otherwise we are just guessing.
goddo Member Since: 27 Oct 2020 Location: south Posts: 83 ![]() ![]() |
Thanks for all the replies with helpful suggestions.
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1850 ![]() ![]() |
Unless its changed recently, the RfR was only if the TPMS light was flashing. If it's on as a solid warning light, it's pass and advise ![]() |
Interestingly, I don't get any warning lights, just tyre pressures all reading zero. If I disconnect the dash cam they come back after a run. I have no idea why this should happen but as an experiment I left the camera connected but put it in a Faraday pouch ( key signal blocker). After a while the readings all went back to zero??
