![]() | Home > My Range Rover > 5 RRs and I have to give up |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2743 ![]() ![]() |
I'm only suggesting that you're making life hard for yourself comparing yours to videos unless you're experiencing a distinct driveability issue that must be resolved. L405 D350 SE Carpathian Grey D5 19" rims |
Full-fat-Lance Member Since: 06 Feb 2022 Location: Essex Posts: 149 ![]() ![]() ![]() |
I wonder if any forum members near you could let you take their car for a spin so you can compare? |
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 757 ![]() ![]() |
I'm just incredibly frustrated after buying 4 different RRs and them all having the same 3 distinct driveability issues (good name for it)
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3327 ![]() ![]() ![]() |
I don't meant to sound patronising here, is it possible that what others can do with 1 hand you can't?
No problem David, no offence taken I understand where you are coming from.
So I've had a few weekends off from this.
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1402 ![]() ![]() |
Its in your head
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 823 ![]() ![]() ![]() |
i wouldn't be worrying about the drop of oil you found but it dose look to dry to me
Okay, so you don't think the oil on this side of the rack is a concern?
So greasing the rack bar doesn't seem to have done anything.
Took everything apart again yesterday, the n/s front strut is aftermarket and the top mount bearing is very gritty and round when turned but does turn freely.
I've found something else whilst looking into shock absorber top mount bearings.
I have a 4.2sc with the dampers removed from the top of the shocks, makes no difference to the ride quality and isn't noticeable under heavy braking, I suspect that if you don't drive like Lewis Hamilton it wouldn't be noticeable, even then doubtful if you'd know whether they were fitted or not... |
