Home > Technical (L322) > Britpart Front Discs TDV8 3.6
GeoffWestWales
Hi All, a while back I bought some upgraded drilled and vented front discs for my 2008 TDV8 3.6 from M and M Land Rover I think they were called, finally got around to getting it booked into a local garage for fitting and he says they are the wrong discs, I have had them to long to return them so guessing are these for the 4.4 tdv8?, the part number on the box is DA4685, can anyone please confirm?
Post #702817 22nd Oct 2024 8:46am
dingg1
A quick google, says brit part suitable for range rover sport and L405
Better off measuring them to be sure I'd say 👍
Post #702820 22nd Oct 2024 8:52am
kevinp
If you do a google search for DA4685 it comes back with L405 and some Discoveries which are bigger discs. Neutral
Post #702822 22nd Oct 2024 8:53am
GeoffWestWales
Thanks both for the replies, the idiots totally sent me the wrong discs then, looks like Ebay it is then, the weight of them no wonder the cars feel so sturdy.
Thanks again for your help both.
Cheers
Geoff
Post #702823 22nd Oct 2024 8:55am
Scouse Exile
Hi Geoff,
I think I got the same type (but the correct part) from Rimmer Bros. I would call them as they were very helpful on the phone to me and they may ask you for the VIN to be sure.
From memory they are 360mm and I think the part number from them is LR031843URBP, at the time I bought them they were £118.00 for the pair. To date they have proved to be very good. The Brembo part is LR31843BREMBO and cost £174.00 at the time but I elected for the cheaper ones.
This assumes of course that you have the Brembo fitment Smile
Jon
Post #702830 22nd Oct 2024 11:03am
GeoffWestWales
Thanks for all the valuable info Jon,that's a great help really appreciate it.
Post #702840 22nd Oct 2024 1:56pm
