![]() | Home > Technical (L322) > Help! I’ve made a booboo |
Scouse Exile Member Since: 09 Dec 2022 Location: East Midlands Posts: 406 ![]() ![]() ![]() |
I’d be inclined to get a hex socket on the caliper bolts as the 12 sided might be a little risky if you’re having to use some force. They are tight but shouldn’t really present too big of a challenge.
RobsterPC Member Since: 14 Oct 2024 Location: Kent Posts: 135 ![]() ![]() |
I’ll take a picture tomorrow but the bolts are definitely not 6 sided ones, I thought they were the weird E ones at first.
You might be right, it’s been a while. |
Just ordered a long 6mm HSS bit to drill the stupid thing out. Fingers crossed for me! |
Ramblin Man Member Since: 05 Apr 2022 Location: Southsea Posts: 306 ![]() ![]() ![]() |
WRT caliper removal: I can’t recall off the top of my head how much room you have to work with. If you can get an impact driver in there I’d try that, optionally with an harmonic inertia socket like this one
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3328 ![]() ![]() ![]() |
Have you got the steering on a lock to give you better access to the caliper bolts?
Thanks David, why didn't I think of that? 😊 |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3983 ![]() ![]() ![]() |
Jack the car up, put the socket and breaker bar on the calliper bolts, put the end of the breaker bar on the ground or a piece of timber. Let the Jack down so that the weight of the car is on the breaker bar and go and have a coffee. Let gravity do the work for you. |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3329 ![]() ![]() ![]() |
Don’t waste time with brute force methods. Buy a battery powered impact driver. Even my cheap Ryobi 400nm ‘toy’ has yet to be defeated on a bolt inc front calipers. It’s not the torque but the percussive action that breaks the thread free. Remember to use ear defenders. Re tightening them is an issue without a lift as you really need to be under the car with a long bar. 2012 TDV8 Vogue (L322) |
Happydaze Member Since: 30 Aug 2021 Location: Wirral Posts: 105 ![]() ![]() ![]() |
What's the torque setting for the caliper bolts on a 4.4tdi? I'm curious as the setting on a 3.6tdi with Brembo calipers is, iirc, surprisingly low. When I removed mine a while ago I was a little surprised as to how tight they weren't!
They are quite tight, see below for the 3.6, but if you use the method described by David which allows for a bar outside of the arch its perfectly possible to do. Significantly it recommends new bolts.
FJ12Jagmen Member Since: 25 Jun 2020 Location: Danbury Essex Posts: 77 ![]() ![]() ![]() |
I managed to round one of the bolts and had to weld another on. Went through 7 nuts which all sheared off before my mate used his arc welder with a dissimilar rod. Even then it took a 5 foot scaffold bar.
Do they look like this? |
That's usually what JLR use for caliper bolts. A good quality 12 sided socket with a 3ft 1/2" breaker bar will get them out and with the steering on a lock you'll have plenty of room to get them in.
