Home > Technical (L322) > CCF file manipulation of emergency brake light
klf400
Has anyone changed their Ccf file to enable flashing brake light or hazard lights ?
Found this while looking at the CCf file
Not sure if this will apply to just the high level brake light or all 3 or a separate light altogether 🤔 1990 3.5 v8 defender
2000 4.6 v8 30th anniversary prins lpg
2004 4.4 v8 vogue prins lpg
2011 4.4 TDV8 Vogue
faultmate extreme
rsw allcoms
Autel 906BT
Gap iiD tool
Post #704682 18th Nov 2024 12:20am
JayGee
It's in the untested section and best to leave such an important saftey function well alone IMO 2012 TDV8 Vogue (L322)
Post #704691 18th Nov 2024 10:12am
pretty sure that on heavy braking the brake lights [flashing] and hazards come on.. ... - .- -.
Post #704692 18th Nov 2024 10:17am
It’s one or the other Stan… Some newer cars flash the brake lights in emergency braking situations and some slightly older models flash the hazard lights…
I’ve personally not messed with the CCF’s changing these parameters as to my mind they should be left alone… Thumbs Up
Post #704712 18th Nov 2024 2:49pm
