Home > In Car Electronics (L322) > Landrover logo and orange flashing light
JT
England 2006 Range Rover Vogue 4.4 V8 Tonga Green
Hi all. Have looked on website to no avail. I have got fibre optic red light coming into boot and leaving boot after going through satnav, radio receiver and Bt module. Any suggestions on what I can check next. Have bypassed modules in boot with fibre optic loop . I can use code to enter screen at front but only can access most setup. can’t access anything else or change time and date. Cheers John
Post #705046 21st Nov 2024 3:02pm
CD changer in glove box area....?? Pete
Post #705049 21st Nov 2024 3:33pm
JT
Thanks. Will remove and have a look. Will let you know out come 👍
Post #705092 21st Nov 2024 9:38pm
JT
Update. Took dash off and checked connections on CD player and touch screen. All okay. So I disconnected all in boot and made up a male fibre optic loop and put this in rear connector and hey presto touch screen works and I was able to set clock and mpg. Removed loop and connected except tv receiver back to square one but if I connected tv receiver apart from fibre optic loop and used my male loop into back of receiver everything works. Ordered second hand receiver. Hope this helps others. Cheers John
Post #706575 11th Dec 2024 1:05am
Good job, you got there in the end, sorry for the bum steer towards the CD….. Pete
Post #706695 12th Dec 2024 2:35pm
JT
No problem Pete.
you don't know what order the modules are attached to the fibre optic loop. Mine wasn't in the correct order to the said diagrams. It is now.
cheers John
Post #706723 12th Dec 2024 8:40pm
