Home > Technical (L405) > What does this flap do?
Viggy17
United Kingdom 2016 Range Rover Autobiography SDV8 Nara Bronze
So, onto the next attempt. This time I used a metal arm secured to the shaft with a centre hole and self tapping screw and bent around the lower part of the shaft where its flat. Then 3 screws onto the side of the flap. So far so good, but I need to test it more. If it tests okay for a few days I’ll reattach the missing piece.
Post #707094 17th Dec 2024 1:18am
marcochezzi
South Africa 2011 Range Rover Vogue SE 5.0 SC V8 Fuji White
Well done, I drove around for around two years with a pair of plastic electrical conduit tubes cut to length holding the flap permanently closed in the recirculate position before I tackled this dog of a job.. must admit she has held up fine to date… Still have the tubes in the glovebox, just in case.. Mr. Green
Post #707096 17th Dec 2024 5:03am
Viggy17
Thanks. Yeah it’s an absolute dog of a thing to fix. It’s not pretty but it works for now!
Post #707257 19th Dec 2024 9:54pm
RR4ED
United Kingdom 2017 Range Rover Vogue SE TDV6 Loire Blue
I tackled it slightly different way, using a hot staple gun. Used a thick staple, pressed in to both cover and the gear and that resolved it for me.
Tested quiet a few times and works fine, its a very light plastic and think should hold fine.
Thank you for the thread though, gave me lots of helpful tips.
I cannot believe how many people brake these.
Post #725280 28th Sep 2025 4:39pm
