Home > Dealership & Service Feedback > Hartington Motors Wigan
tigmutt
My recently acquired 2011 L322 requires a new oil cooler. The used car warrantor has declined the independent specialist I wanted to use and is saying I must use these guys. Their web site suggests that are a used car dealer that does services and body repairs. Does anyone have any experience of them?
Also that have quoted this as a four hour job. Is that enough?
Any advice appreciated.
Post #706228 6th Dec 2024 11:04am
JoolsB
United Kingdom 2012 Range Rover Vogue TDV8 Buckingham Blue
No experience of that dealer unfortunately but I have recently changed the oil cooler myself and if they are quoting 4 hours labour then that would seem pretty reasonable, there is a fair bit of faffing to get to it.
Post #706838 14th Dec 2024 11:53am
Scouse Exile
Did you buy it from them or are they simply local and approved by the insurers?
If you check the warranty they usually have a maximum hourly rate they will pay, typically £70 or so, they may be rejecting it because of this perhaps although you SHOULD have the option to pay the difference I would hope if you feel it’s better going to a specialist.
Have a read of the policy cover and maybe give them another call.
J
Post #706873 14th Dec 2024 6:45pm
tigmutt
Hi both, thanks for the replies. The warranty is capped at £50 an hour, which I thought was low but they have agreed it with Hartington. I bought the car elsewhere so have no experience at all. The garage I wanted to use was charging £65 an hour and quoted 8 hours which is why I was worried about Hartington. I am going to go with Hartington and cross my fingers!
Post #706880 14th Dec 2024 8:48pm
Scouse Exile
Good luck, let us know how you get on.
J
Post #706887 14th Dec 2024 9:53pm
