Home > Maintenance & Mods (L405) > P400e High voltage heater
hoppy_70
England 2018 Range Rover Autobiography 2.0 PHEV Loire Blue
I thought I’d share my experience with the P400e HV heater. I bought a Sport about 18 months ago and ended up rejecting it as the HV heater had failed and they were on 6 months back order. It’s a £1500 repair at JLR and £600 of that is labour as they quote a few hours (it took me 20 mins last time!).
I’ve recently bought my L405 P400e and got it in summer when the issue isn’t as noticeable.
Symptoms - the car SHOULD run and drive from first start on EV mode, provided there’s enough charge and the aux battery is good. If the aux battery isn’t good it can run on engine to charge it now and again. For £60 I just replaced mine.
When the HV heater has failed it will use the engine to warm the car to whatever temp you ask for via the controls. If you turn off the heating completely and it runs in EV mode normally, then this heater has failed.
I tried a couple of second hand ones and it highlighted how frequently they fail as both were the same as mine (one was manufactured in 2022!). The offending part:
It’s made by webasto and is effectively a kettle that heats the coolant. This will also run if you pre heat via the app. (Another sign it’s failed if you can’t get pre heating to work).
I couldn’t find any advice about changing it so thought I’d post this up to help other numpties without a warranty, like me. The parts about £950 at LR but I got a genuine item from land ranger services for £850. Comes with a 2 year guarantee now, which I feel I may need!
I think the dealers power down the HV battery to swap it over, which seemed overkill to me so I just swapped the item. Given it was my third time it was really easy to do.
Undo the t30 and 10mm bolts pictured:
Then disconnect all three electrical plugs which have little red tabs and are fiddly (the hardest part].
Disconnect the two water pipes with the buttons (you lose about a cup of coolant) Lift the whole thing out then swap over the carrier and pump then put it all back. Bleed the air out of your coolant and top up. The new part number (original was superseded) is LR187238
If you clear the codes then the car will go through a process of re-learning the battery usage. This will make it feel like Ev isn’t working but it’s just a process it goes through over about 20 miles (may be less/ time based). Once this is done it should work exactly as it should switching to EV mode when YOU want it to, rather than to heat your water!
Mines working great now. Hope this helps someone as it was a bottle tester for me swapping this without powering down, but seems like a ‘health and safety police’ part of the procedure. My Previous RR's!
2018 P400e Autobiography
2008 TDV8 Vogue
2006 TD6 Vogue
2007 TDV8 Vogue
2007 RRS (I know, it doesn't count!)
2005 4.4 Vogue on LPG
2005 TD6 Vogue
2003 4.4 Vogue
2001 4.6 HSE
2000 2.5 DHSE
1999 4.6 HSE
1997 4.6 HSE on LPG
1995 2.5 DSE
1989 3.9 EFI classic
1988 3.5 EFI classic
Post #706319 7th Dec 2024 3:05pm
chicb
United Kingdom 2018 Range Rover Autobiography TDV6 Barossa
That's a very good write up Thumbs Up
Is there a section where things like this can be stored for future reference, rather than trying multiple keywords to search or is it just me who struggles to find things Big Cry
Post #706329 7th Dec 2024 5:15pm
Chip41
United Kingdom 2017 Range Rover Autobiography SDV8 Loire Blue
Heroic - great write up and just what I need to do.
Out of interest what is the procedure to bleed the air from the coolant system?
Many thanks
Post #706409 8th Dec 2024 6:28pm
hoppy_70
There are three bleed screws (two to the left side of the engine and one above the FBH back left. Just open them when running to let the air out.
Incidentally, when the bonnet is up it disables EV mode so you can run the engine. My Previous RR's!
2008 TDV8 Vogue
2006 TD6 Vogue
2007 TDV8 Vogue
2005 TD6 Vogue
2003 4.4 Vogue
2001 4.6 HSE
2000 2.5 DHSE
1999 4.6 HSE
1997 4.6 HSE on LPG
1995 2.5 DSE
Post #706729 12th Dec 2024 9:51pm
Walter Skinner
Bulgaria 2019 Range Rover Autobiography 2.0 PHEV Barolo Black
Thank you for this report as I've just stumbled upon exactly the same issue. My P400e does not start in EV/Hybrid mode and with the temperature went down it runs 90% on ICE. It starts in EV (Hybrid, with no EV button active) with climate off, so apparently my HVH is down, waiting for the code reader delivery to confirm.
Can you please make a picture of your new unit, what model it is? I'm struggling to find info on how to pick a proper model, I know its been updated to "Gen. 1.5".
My original is HVH 50 Plus
Discovered online:
HVH 50
HVH 70
HVH 50 Gen 1.5
HVH 70 Gen 1.5
Not clear what that "Plus" in my stock part means, can't find the "Plus" version on sale. Search by partnumber provides the list of vendors selling the part, but no one states if it is 50 or 70, Gen. 1.5 or no.
So, can you please make a pic of your new part & possibly give a hint where you got it?
Mine:
Post #707803 29th Dec 2024 9:04am
hoppy_70
Hi, the part number for the newer version of your heater is in the original post. If you google that number you’ll find a few on line. It’s a main dealer part, but I bought mine from a LR parts specialist called landranger. New genuine LR part has 2 year warranty. I think my original item was 50 plus, but the new part is 70. I can’t picture as it’s installed. My Previous RR's!
2008 TDV8 Vogue
2006 TD6 Vogue
2007 TDV8 Vogue
2005 TD6 Vogue
2003 4.4 Vogue
2001 4.6 HSE
2000 2.5 DHSE
1999 4.6 HSE
1997 4.6 HSE on LPG
1995 2.5 DSE
Post #708033 1st Jan 2025 8:04pm
paul r
What does FBH mean? Anyone got a picture of the location of the bleed valves?
Thanks,
Paul.
Post #716004 12th Apr 2025 8:43am
FBH = fuel burning heater...
Thumbs Up ... - .- -.
Post #716006 12th Apr 2025 8:45am
paul r
This is what confused me. It hasn't got a FBH, it's a petrol hybrid. The HV heater heats the cabin..
Post #716007 12th Apr 2025 8:48am
paul r
Ah, found it. Front bulkhead
Post #716008 12th Apr 2025 9:00am
paul r
Hi,
I replaced my HV heater today. Used the instructions above. Took me a while to work out how to get the connectors off, especially the HV one. I pulled the tab up, but still wouldn't come off. Then I realised you have to press a little grey tab in towards the connector. Apart from that it was straight forward.
I ordered a Hv heater from AliExpress. It's an original JLR part and only cost me 380! A bit better than the 960 the dealer wanter
Cheers.
Post #716018 12th Apr 2025 11:46am
rk7
United Kingdom 2019 Range Rover Autobiography 2.0 PHEV Carpathian Grey
Hey Paul,
Can you please share a link to the AliExpress item? Mine is bust as well and I’m thinking I’ll try a second hand one first but if that doesn’t work I’ll get the AliExpress one.
Thanks,
RK
Post #717955 15th May 2025 9:14am
smola
Poland
Hello
I have a question - I replaced the heater but after the replacement it goes even crazier than before. There is no information that EV is unavailable but in practice the car does not want to drive in EV anyway. It will almost always start the engine after switching on the ignition, sometimes it will start in EV but after a while it starts petrol engine anyway.
In addition, when starting it throws the information "intelligent emergency braking system unavailable" and disappears after a while, but interestingly the petrol engine turns on exactly when the message is displayed, although not always...
Is any adaptation required after the replacement, etc.?
The engine errors that popped up after the replacement were deleted, driven a few km and no changes..
Post #719975 18th Jun 2025 8:31am
Adrian JW
That does sound like the auxiliary battery may be failing. It's a relatively cheap fix, so worth trying.
Post #721180 12th Jul 2025 10:25am
