![]() | Home > Maintenance & Mods (L405) > Transmission sump shield |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 796 ![]() ![]() |
An angle grinder. |
will308f Member Since: 19 Apr 2022 Location: plymouth Posts: 603 ![]() ![]() ![]() |
yea i think that is going to be the only way as i can’t get a spanner in there to hold the nut ,better go and get new bolts/nuts |
baz000000 Member Since: 01 Apr 2022 Location: Shropshire Posts: 154 ![]() ![]() ![]() |
The clips corrode through but I have managed to get two to come off using an impact. The weight of the shield pulled down a bit did create enough drag to enable the nut to turn slower than the impact drive, unwinding after a few minutes. A far easier approach than grinding. |
yea did use an impact in the end but the bolt if free however the nut on the inside also turns that’s my issue i can’t get anything in to stop it which is very annoying if i had a spanner that i could get in there dam frustrating |
