Home > Maintenance & Mods (L322) > Auxillary coolant pump leak - fixed
fanders
United Kingdom 2009 Range Rover Autobiography 4.2 SC V8 Buckingham Blue
Over the past few weeks I had noticed a coolant leak on my tiled garage floor (Ecotile PVC tiles, very good product), which seemed to be getting worse. Having run for a bit by topping the coolant up, the time came for a proper investigation. I thought it likely that the new radiator I fitted earlier this year may be leaking, perhaps from one of the o-rings on the hoses which I hadn't replaced when I changed the radiator, but everything was dry at the front of the coolant system. Closer inspection revealed dripping coolant from the auxillary coolant pump on the left side of the engine bay, down near the left bank exhaust manifold. This small pump is tucked away behind a foil heat shield, together with two solenoid coolant valves:
The heat shield is secured with three 10mm nuts, the lower of which was a right bu**er to get to as access is limited due to the proximity of the left side of the engine:
I managed to get the lower nut off with my Harbour Freight flex-head long reach ratchet with a deep 10mm socket on the end:
I bought this tool on my last US trip, having seen Christian use one on an LR Time youtube video. It was the only thing I had in my toolkit that worked, and access from below is worse than from above.
With the heat shield removed, the auxillary coolant pump becomes visible, along with the leaking coolant:
This pump pushes coolant through the heater core, so I learned that my 4.2 supercharged has three coolant pumps - 1. Engine (belt-driven) coolant pump, 2. Supercharger (electric) coolant pump and now 3. Auxillary (electric) coolant pump.
To remove the pump, the inlet and outlet hoses must be removed. These are held in place with wire clips, and some idiot at JLR designed these so the top of the wire clip is facing the chassis rail, rather than inwards towards the engine where access is (relatively) good. One needs to insert a pick or thin screwdriver to pull the wire clip away from the hose end fitting, before releasing the hose. It took me probably two hours of skinned knuckles before I finally had the hoses off and could release the pump.
This is the pump - it's a BMW part, p/n 6 904 541. I bought a salvage item for £30, a new pump is about £80:
Once removed, some material could be seen along the pump casing joint:
On splitting the pump, this turned out to be remains of the pump casing sealing o-ring which had been extruded out by the coolant pressure. I put this down to the heat of the left exhaust manifold, which is very close to the pump, probably softening the o-ring material in use.
I changed the pump for the salvage item and reassembled everything. No leaks were present when the engine was run, proving this failed pump o-ring was the cause of the leak. I hope this write-up helps someone else when trying to find the cause of a coolant leak on their L322. ---------------------------------------
2009 4.2 SC Buckingham Blue
2021 Hilux 2.4
Post #707045 16th Dec 2024 4:57pm
Strider
Thanks for a brilliant write up, The pictures were ace. Thumbs Up You mention using floor tiles, have they been down long and did you have to seal the concrete floor before laying them?
Peter
Post #707060 16th Dec 2024 8:25pm
fanders
Floor tiles
The floor tiles have been down since January 2021, so about four years now. They have stood up to cars going in and out, along with trolley jacking loads very well. If fluids are spilled they do tend to seep down between the cracks but it's easy to lift a few tiles and clean up. I have noticed some black marks where tyres sit in the same place, but they are minor. Being plastic they don't like sharp, heavy objects being dragged across them as these score the surface, but on the flip side they do add a bit of relative 'warmth' compared to bare concrete or porcelain tiles.
They were easy to install, I had flaking garage floor paint which I didn't bother to reseal and have had no issues. I would imagine they would be fine even over a dusty concrete slab. I used Ecotile 7mm PVC tiles, it was about £1,800 inc VAT to buy them for my 5.7 x 5.9m garage including the ramp sections at the garage doors.
Temperature conditioning the tiles prior to laying:
They go down quickly, but get kneepads:
Cutting to fit the edges can be done on a mitre saw, a bit messy with plastic swarf but it gave a clean cut. The pros use a guillotine. I left a 5mm expansion gap around the edge and have had no issues with tiles expanding, but my garage doesn't get much direct sunlight through the doors when open, being under trees. I painted the floor edge with a hand-mixed grey paint to hide the expansion gap and generally neaten the edge up:
fanders Thumbs Up ---------------------------------------
2021 Hilux 2.4
Post #707076 16th Dec 2024 11:03pm
Strider
Very nice interior, the tiles do finish it off well, I like the chunky wooden doors Thumbs Up
Peter
Post #707084 16th Dec 2024 11:54pm
