Home > Technical (L322) > Instrument swap
Philcaz
Instrument swap
Hi guys
I’ve got a problem hopefully someone can help me with
I swapped my clocks over because my old ones had bad pixels now Im getting suspension inactive and
All my abs lights are on and won’t go off
Does anyone have any ideas on how to sort this I’ve plugged it into my diagnostic tool but no faults are showing
It’s a 2004 4.4v8 petrol if that helps
Cheers Phil
Post #708067 2nd Jan 2025 9:21am
fisha
Have you tried turning the steering wheel from lock to lock ? Then going for a drive ?
After working on the car sometimes the system needs to re-learn the full range of steering positions. Steering from lock to lock does this. This can apply to things like the ABS system errors too, as part of the stability control system relies on knowing what the steering angle is in order to apply ABS to try and bring the car under control. If it's not re-learned it, it can't work the stability / abs system properly. V8 or else ...
Post #708078 2nd Jan 2025 11:26am
Philcaz
Thanks for the reply
Yeah I’ve tried wheel from left to right and had a drive it seems to drive ok but the lights are on and suspension isn’t working now but I can hear the pump coming on
lol it’s gone mental
Post #708079 2nd Jan 2025 11:31am
mjdronfield
Not an expert but I think the cluster needs coding to the car.
When I had the pixel issue on my 2003 you could just buy a repair kit and garage replaced the ribbon to the LCD……
Hopefully you haven’t created more issues to fix.
Wonder if now you can send your original cluster off to be fixed and then replace it when it comes back. Not helping you now I know……
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #708087 2nd Jan 2025 12:01pm
bgennette
Australia 2003 Range Rover HSE Td6 Java Black
Have a look at this thread 'Switching L322 out of BMW Transport MODE' on here.
Its for reprogamming the ZKE, but the method should work for reprogramming the cluster module too.
bye. 2003 TD6, EGR delete, vortex crankcase breather update, performance chip, UHF 2 way, Android head unit, crash camera on dash, always-on rear view camera to mirror screen, LED DRL`s, Electric trailer brake controller. FSR replaced. Pulling 3T caravan all about Australia
Post #708155 3rd Jan 2025 3:51am
