Home > Technical (L322) > Charging Fault on Dash - GAP IID No Fault
UpsideDownTub
United Kingdom 2012 Range Rover Westminster 4.4 V8 Orkney Grey
After a faultless year of lovely motoring my 2012 TDV8 Westminster has thrown up a charging fault and restricted performance on the dash but when I plugged in the GAP IID tool it shows no related faults. The fault showed this evening, it was cold (-1), all electrical comforts were turned on and the fault popped up on the dash. One other issue I noted, the electric windows are slower than normal... Any thoughts would be welcomed. Range Rover 2012 TDV8 Westminster
Post #708208 3rd Jan 2025 8:08pm
JMC
Battery would be the first port of call, then alternator..... The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #708237 4th Jan 2025 6:41am
AndyRoo
Scotland 2012 Range Rover Westminster TDV8 Fuji White
Hi,
I had similar when I changed the battery, turned out to be the tiny wire on the negative terminal that goes to the battery monitoring unit had become dislodged. Cleaned and refitted, that cured it.
There's a similar cable on the +ve terminal, that has a tendancy to snap as it's an eye crimp.
Should actually give an error code if these fail though, can't remember what it was.
A. Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #708265 4th Jan 2025 4:15pm
UpsideDownTub
Thanks both, I will check that in the morning and then nip down to Halfords to check the battery, other than that I will need to charge the battery up to ensure it has enough oomph to get me to my favoured mechanic. Range Rover 2012 TDV8 Westminster
Post #708309 4th Jan 2025 11:52pm
Apps
United Kingdom 2010 Range Rover SE TDV8 Santorini Black
I'm having the same issue still after new alternator and battery so I mite check them wires aswel
Post #708314 5th Jan 2025 12:48am
