Home > Technical (L322) > New Battery Question
Eastsoutheast
United Kingdom 2012 Range Rover Vogue TDV8 Santorini Black
I had a new battery fitted just under 2 years ago. It was a Yuasa Silver non AGM with a 5 year waranty. It wasn't coded to the car when fitted.
I have just had a replacement fitted which is now a quality AGM version.
Does the car need to be told it has a new battery to ensure its correctly charged?
My son tells me this battery will die early as the car will over charge thinking it's an old battery.
Thanks 2012 4.4 TDV8 Vogue Santorini black ivory leather
Post #708464 6th Jan 2025 5:35pm
JayGee
Idealy yes. If you realy care about the best possible care and upkeep of your car you would be wise to get a GAP IID tool and you can do it through this. 2012 TDV8 Vogue (L322)
Post #708465 6th Jan 2025 5:38pm
Eastsoutheast
Hi Jay
I have one I purchased from here approx 6 months ago and haven't got around to buying the license. I will sort this week and start using.
Post #708470 6th Jan 2025 6:47pm
AndyRoo
Scotland 2012 Range Rover Westminster TDV8 Fuji White
I did but the GAP Tool doesn't go as high as the battery spec, nor does it differentiate between different battery types.
It might have something to do with monitoring battery health, but I find it's total rubbish as a device in itself, even when 100% charged on the bench and then put in it never registers above 78%, that seems to be it's ceiling, in my car that is.
So I set it to the highest spec in the tool. If it does do something then whatever it is it's not covering my particular battery.
A. Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #708529 7th Jan 2025 12:29pm
JayGee
Did you use an AGM charger? 2012 TDV8 Vogue (L322)
Post #708543 7th Jan 2025 3:23pm
