Home > Maintenance & Mods (L405) > Unplugged cable drivers seat
Graham4242
United Arab Emirates 2011 Range Rover Autobiography 5.0 SC V8 Alaska White
While cleaning out the L405 I noticed an unplugged cable under the drivers seat. Couldn’t see where it went so I took the seat out. Anyone got any ideas? Highlighted in the picture below.
 Current
2011 Autobiography, 2014 Vogue SE Supercharged
Previous
2016 Cayman GTS
2015 Cayenne Turbo
2016 911 Turbo
2013 Audi S8
2014 Cayman S
2003 Alpina B5s
1998 M5
1993 M5
Post #708907 12th Jan 2025 6:39am
Spridget
United Kingdom 2015 Range Rover Vogue SDV6 Corris Grey
I could well be wrong but I thought that yellow connectors were usually for air bags. I know from experience that airbag connectors under the seat can be troublesome and wonder if someone has done some kind of mod to stop the light from coming up?
Other than that, could it be for something that your particular model doesn't have like vibrating seats or something?
Post #708912 12th Jan 2025 10:29am
4RRS
United Kingdom 2016 Range Rover SVAutobiography SDV8 Corris Grey
I'd agree, mine is the same. JLR fitted a wiring overlay loom as the original is too short and causes loss of connection and hence the airbag light pops on.
They fit the new loom but leave the original in situ as its taped to other cabling and hence not easy to remove.
Tuck it away and forget about it! L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #708917 12th Jan 2025 11:04am
Graham4242
Copy that, concern filed in the bin. Thank you very much for the reply’s. Current
Previous
2016 Cayman GTS
2015 Cayenne Turbo
2016 911 Turbo
2013 Audi S8
2014 Cayman S
2003 Alpina B5s
1998 M5
1993 M5
Post #708938 12th Jan 2025 2:10pm
Dolphinboy
can someone please point out the airbag plug in on the pic used here? trying to get my light to stay off so going to attempt to secure it a bit better.
also, is there an official LR recall/Tech bulletin for this airbag cable replacement?
TIA
DB.
Post #708942 12th Jan 2025 3:31pm
Graham4242
I don’t know if this helps but I had an airbag warning light coming on intermittently. It was from the seat. Did a bit of YouTube digging and I found something that work for me. So on my LHD car looking at the back of the seat on the left hand side the foam bolster rubs against the plug giving the intermittent fault. The video suggested cutting a small amount of foam out so that the plug remains un-disturbed. Since then no faults and zero difference in how the seat feels. I don’t know if I can link a video but you can try searching for “BOO2O-13Range Rover air bag warning light common problem” it’s not in English but it does have subtitles. Sounds drastic and I wouldn’t normally try something like that but the connector in mine was just like in the video and when I gave it a wiggle the airbag warning light went off. Current
Previous
2016 Cayman GTS
2015 Cayenne Turbo
2016 911 Turbo
2013 Audi S8
2014 Cayman S
2003 Alpina B5s
1998 M5
1993 M5
Post #708945 12th Jan 2025 3:47pm
