![]() | Home > In Car Electronics (L405) > ghost 2 |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35770 ![]() ![]() |
question for those who have had this ghost 2 fitted for a number of years, are you happy with it, does it work ok?
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1168 ![]() ![]() ![]() |
Kot is the man on this! |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1210 ![]() ![]() ![]() |
I have had it for about 18 months, It gives peace of mind but just remember every time you turn the car off you have to put the code back in.
can it be 'off' for normal local use and then activated when parking in london for instance..
chicb Member Since: 28 Nov 2019 Location: Dundee Posts: 131 ![]() ![]() ![]() |
I have had mine for a few months. Easy enough to use, but sometimes it does not work. Try again, may or may not work. Always works eventually, most I have had is 3 goes before working. Tried to figure out where I went wrong. Press keys, normally, slowly, quickly. Foot on brake normally or really firmly, I can't see where I went wrong. Valet mode is good when putting the car in for a service. I sometimes leave it in valet mode for day's so it's a normal start, but that is defeating the reason to have it installed.
The only time mine has not worked is when I have tried to engage gear and not put the code in first then it cuts the engine,
interesting feedback , thankyou. |
Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1404 ![]() ![]() |
I am more than happy with it, had mine 3+ years. I would fit it to any future compatible vehicle.
thanks for that kot, very informative... |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1475 ![]() ![]() |
Unknown to me until I collected it, my Fifty came with a Ghost 2 already installed. My first reaction was to have it removed as it just seemed unnecessary for me but thought I’d at least give it a chance. Once I had got used to using the button sequence (occasional user error |
i wouldnt want mine back either if it had got stolen Rob.
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 490 ![]() ![]() ![]() |
Stan, I have the META-TRAK S5 deadlock fitted to mine, very pleased with it. You get a tag where the car wont start without it, also an app on your phone you can do all sorts with including immobilise or use an emergency unblocker in the event of a faulty tab, it needs a subscription but I feel its worth it for the functions with it. Dave |
thanks for that Dave..
Yes put the tab on your keyring |
