![]() | Home > Technical (L322) > How far could I drive with a dead alternator? |
ashtrucker Member Since: 30 Jan 2012 Location: lincoln Posts: 51 ![]() ![]() ![]() |
I’m in exactly the same situation 2012 Westminster 4.4 tdv8 |
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1510 ![]() ![]() ![]() |
Been waiting almost two weeks to get mine done going in on the 27th to my local independent specialist 2012 Westminster 4.4 tdv8 |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2742 ![]() ![]() |
If the alternator is shorting to ground then the battery will last only a few minutes. I installed a separate alternator cable via its own fuse in my L322 so that I can isolate the alternator yet still start the engine the next time the alternator fails. |
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1262 ![]() ![]() ![]() |
I used to have a 52 plate Peugeot 206CC ( I know its not the same as a Rangey!), but there was a problem with my alternator as I used to get a random 'Battery Charge error' notification. I could usually get it back home, however one day I was travelling to Chipping Norton where the company I was working was to pick up a new laptop (WFH), and it gave the warning message, I carried on for a couple of miles then the fuel and temp gauge started going haywire, followed by a slight misfire, then a bigger misfire.
Crusty21 Member Since: 29 Mar 2022 Location: Cheshire Posts: 48 ![]() ![]() ![]() |
Just to add a bit of background to the story ........
Again, it was with my Peugeot.
You may be right there Paul |
UPDATE ...... Fully charged AGM battery got me to the garage |
When 1 diode in the alternator shorts to ground it will draw 80-100 amps which will flatten a battery very quickly. |
Cav Member Since: 18 Nov 2024 Location: Herefordshire Posts: 17 ![]() ![]() |
This is the update I have been waiting all weekend for! Glad you made it. 2021 Westminster Black D300 MHEV 1990 3.9 V8 manual Vogue - sold in 2000 |
mgrover Member Since: 03 May 2020 Location: Leeds Posts: 422 ![]() ![]() ![]() |
i was in an L320 and managed 7 miles
Meerbusch Member Since: 16 May 2012 Location: Zürich (CH) + Düsseldorf (D) Posts: 325 ![]() ![]() ![]() |
Hello from Düsseldorf to the English group: I picked up a customer car (L322 TDV8 4.4 2011) with the same problem 10 miles to my workshop, installed a good used battery beforehand and then drove off. Replacing the alternator is actually easy, first remove various panels and hoses, then loosen the mostly rusted screws from the fan wheel cover (takes over an hour), then loosen the 36mm fan, take it out and then loosen the two alternator screws from below, and Loosen the one at the top, take out the alternator and loosen the cables. ATTENTION with the cooler, place cardboard between them. In my case, however, the cooler was leaking slightly at the bottom and was not visible before, so I also have to replace the cooler, which has to be completely removed along with all the other coolers. It's supposed to be delivered the day after tomorrow, I'll report back. The alternator is already in there... L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021 |
Mine gone in today for a new alternator looking forward to the small bill to come 2012 Westminster 4.4 tdv8 |
