Home > Maintenance & Mods (L405) > TDV6 EGR Valves
Spridget
United Kingdom 2015 Range Rover Vogue SDV6 Corris Grey
TDV6 EGR Valves
This might be me trying to fix what's not broken but- my TDV6 mono turbo runs fine delivers good mpg and a reasonable distance between DPF regens. My concern is, looking at the EGR valves using the Kot Kit or Icarsoft, the B valve is exactly where it should be, ie actual and commanded numbers are just about the same. The A valve is all over the place, open at rest when it should be closed and open during regens.
No mil on and my indie says I should forget about it and be thankful that it's running OK. 😐I have a newly acquired Gapiid tool, is there anything more that it might tell me? The attached graph is the A EGR valve before, during and after a DPF regen.
Any theories and ideas most welcome.
Post #709690 19th Jan 2025 9:25pm
cass
IMHO your indie is offering good advice
Post #709696 20th Jan 2025 12:15am
Spridget
As a follow-up to my original post, and as often happens, the problem was probably due to Pilot Error.
I finally got around to looking at the EGR valves with the Gapiid tool and the readings are where they should be.
My car is a mono turbo and the only profile I could get to work for DPF regens with the Kot Kit was the Jaguar F Pace, which is probably twin turbo. So a case of wrong profile. Not sure why the icarsoft gives the same erroneous readings but all's well that ends well......for the minute.
I almost got into changing EGR valves unnecessarily through a Schoolboy error.
Never too old to learn. Embarassed
Post #716186 16th Apr 2025 8:52am
Gremlin500
@Spridget:
Brave of you to admit the misjudgement, however also very useful to hopefully prevent some othe poor soul coming along and dismantling or replacing stuff that didn’t need it, so good on you! Bow down
BTW, you have the same model as me: Vogue, mono turbo V6.
At first, I was a bit dismayed to have the ā€œpoor relationā€ L405, however have come to realise that there is far less to go wrong with these cars, and it may be a blessing in disguise. Thumbs Up
So far, 3 years and not a single fault. (Put my size 9 in it now, probs! Rolling with laughter ) V6 Vogue - ā€œLess is Moreā€ - less to go wrong!
Post #716191 16th Apr 2025 10:46am
