Home > Technical (L322) > Tell me about LPG on a 5.0S/C.....
JW911
I'm just doing a bit of advance research prior to changing the current FFRR in the next couple of years. The plan is to buy one of the last L322s with low-mileage, which should hopefully be well under £40k by then.
The options are either a 4.4TDV8 or a 5.0S/C with LPG. I currently run a BMW 4.4 with a Prins LPG kit but I'm interested to know about whether I need Flashlube in the Jag engines or modified heads or anything else of interest, which I don't currently worry about.
Thanks.
Thumbs Up 2021 3.0 P400 Vogue
2012 4.4 TDV8 Westminster - gone!
2007 3.6 TDV8 Vogue - gone!
2003 4.4 V8 HSE (LPG) - gone!
2018 F-Pace 25t Portfolio
1974 LR Series III Lightweight FFR
2014 BMW 640i Gran Coupe
Post #78297 30th Aug 2011 6:02pm
IIRC JE say they wont convert unless the head is replaced on a certain type of engine as it soon kills it otherwise. i would say the 5.0 may be harder wearing due to tighter emmissions regs but it does take a lot of power already so be careful...
Post #78299 30th Aug 2011 6:11pm
bozmandb9
2013 Range Rover Vogue SE TDV8 Causeway Grey
They sure did, and it was on the 4.2 S/C, but I believe there are now at least four supercharged's with LPG on this forum alone, I'm about to do another too! Another I'm aware of has done nearly four years and 170k since conversion. 2012 SDV8 Vogue SE
Post #78310 30th Aug 2011 6:42pm
