![]() | Home > Technical (L322) > most of 4.4 dash not working |
zxrjohn14 Member Since: 01 Feb 2025 Location: Spalding Posts: 19 ![]() ![]() ![]() |
if anyone has this problem in the future it is burnt chips or resistors on the board.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8797 ![]() ![]() ![]() |
Glad you got to the bottom of it... |
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 550 ![]() ![]() |
That's good to know, I had an Audi A8 that required the dash to be coded, VAGCOM diagnostics couldn't do it from memory, so was a main dealer job... £££'s I suppose your mileage will need to be corrected? Or when it comes time to sell, do you just sell the vehicle complete with the old set of clocks? Would be interesting to know if GAP IID shows a difference in mileage between the instrument cluster and one of the other modules that stores mileage, or whether those other units just pull the mileage from the instrument cluster? J 1992 RR Classic 3.9 efi Vogue 2014 Disco 4 HSE =================== Both my fatties now gone... Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus) |
the mileage in the dash will be just in the dash (i think) and modules will be recorded as to the mileage they have done... if they record mileage
