Home > Maintenance & Mods (L405) > Turbine intake shut off valve selenoid
Pat
Scotland 2013 Range Rover Autobiography SDV8 Causeway Grey
Hi I am trying to track down the Turbine intake shut off valve solenoid for my 2013 RR A/B 4.4 SDV8 Has any body found one if so could you point me in the right direction as I cant find one anywhere even on LR Parts live chat they kept showing me the secondary turbo which has shut off valve as part of it but they could not find the solenoid that controls it
Post #711333 7th Feb 2025 5:21pm
if its this bit you are on about its available as a repair kit LR033284
 There is nothing that can't be fixed with a hammer๐Ÿ˜œ๐Ÿ˜œ
Post #711359 8th Feb 2025 11:13am
Pat
Thanks for that no its not that bit I will try and attach diagram to show which bit
I can't seem to able to attach diagram to this post
Its the shut off valve which is attached to secondary turbo There is a solenoid attached to that via vacuum hose It is that solenoid I am try to get
Post #711436 9th Feb 2025 4:14pm
RRfranz
Austria 2011 Range Rover Vogue TDV8 Santorini Black
Good evening!
I'm afraid it's the complete part with pipes and valve - LR038174 (Lrcat - VACUUM CONTROL AND AIR INJECTION 4.4L DOHC DIESEL V8 DITC )
Post #711457 9th Feb 2025 6:36pm
Ah I see that bit on micro cat now.
If it is the part you are looking for Itโ€™s superceeded to LR076025 ๐Ÿ‘๐Ÿป There is nothing that can't be fixed with a hammer๐Ÿ˜œ๐Ÿ˜œ
Post #711470 9th Feb 2025 9:04pm
