Home > For Sale & Wanted > [Sold] 2010 Range Rover 3.6 TDV8 Autobiography
JCW
I’ve decided to sell my current Range Rover so thought I’d advertise on the forum to see if there’s any interest before listing it on Autotrader.
It’s an MY10 (first registered Oct 2010) 3.6 TDV8 Autobiography in Santorini Black with black perforated leather interior, including dashboard, door cards, pillars and roof lining, which is relatively rare to find. It’s well specified with most of the options that were available when new, aside the deployable side steps.
Heated / cooled front & rear seats
Electric lumbar & reclining rear seats - controls on rear door cards (inc. correct parcel shelf with flap)
Vision assist pack - 360 degree cameras (all 5 working faultlessly) & blind spot monitor mirrors
Adaptive cruise control
Rear Screen Entertainment with original remote and 2 x headphones
Dual view screen
Adaptive & cornering headlights
FBH remote heating with fob
Both original keys are present & working.
It’s never had a tow bar fitted.
It has the Unique Auto Developments CarPlay system fitted, which allows you to toggle between the standard LR system and the CarPlay system as required. I use this with my iPhone and it works very well.
I have fitted newly refurbished genuine style 18 wheels, all fitted with Pirelli Scorpion Verde 255/55/20 tyres with 8mm even tread remaining, all completely unmarked and as new.
I’ve recently completed an oil service / air filter and fitted new front brake pads.
Prior to my ownership, it had a BAS EGR delete and remap (invoice present) together with BAS intercooler hoses. On checking the oil level today (using the good old fashioned dip stick that LR removed from later models Rolling Eyes ) the oil has remained a clear golden colour, no doubt the EGR delete is keeping the oil nice & clean.
They also fitted the larger 6 pot Brembo front brake calipers / discs as fitted to the 4.4 TDV8 / L405’s which are in their original Brembo red painted finish with white logos.
It has a comprehensive service history with a folder full of supporting invoices and the original service book stamped accordingly.
Current mileage is 142k so it’s been used as intended, however the condition of both the exterior and interior belies the mileage and is very good indeed. There are a couple of blemishes to the bodywork; a small scrape to the nearside front wing and a slight indentation to the panel just above the windscreen. The interior has no undue wear at all. It has genuine carpet mats fitted which remain in good condition. The boot area is also without any notable wear. It has a 20” spacesaver spare wheel which looks unused.
The upper tailgate has no notable corrosion to the lower lip and the rear wheel arches whilst showing some usual surface corrosion, only require a rub down and repaint to address.
It starts and runs quietly, with no smoke whatsoever when starting from cold or hot, idling or when pressing on once warmed up and exercising the engine. Being the 3.6 engine, there is no DPF to worry about. It moves smoothly up and down the gears, the air suspension works as it should at all levels with no hesitation raising / lowering and no odd noises.
In the time I’ve had it it’s averaged just over 25mpg including a mix of motorway, A, B and local roads.
Hopefully the photos show everything described - happy to send more photos to anyone who wants to see anything else specifically.
£Sold
 Jonathan
2010 L322 5.0 SC Autobiography Black
2007 Defender 90 XS Hardtop
Post #711438 9th Feb 2025 4:22pm
DrRob
If my new Defender Censored me off anymore then I’ll buy it Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #711444 9th Feb 2025 4:53pm
JCW
Ready when you are Rob 👍 Jonathan
Post #711459 9th Feb 2025 6:42pm
lovely motor Jonathan.... Thumbs Up ... - .- -.
Post #711476 9th Feb 2025 10:10pm
Johnte
Hi. I'm interested - just going to PM you a few questions over Thumbs Up
Post #711477 9th Feb 2025 10:15pm
JCW
Service history -
PDI @ 3 miles, Stratstone London, 01-09-10
A Service @ 16,734 miles, Ecoeur Automobiles LR, Dents-du-Midi (France), 21-11-11
Inspection 1 @ mileage not recorded, Guava LR Guildford, 23-04-13
Oil Service @ 28,418 miles, Dashwood Service Centre, High Wycombe, 13-05-2014
Oil service @ 40,494 miles, Lancaster LR Reading, 26-05-15
B Service @ 56,525 miles, Rovertune Reading, 01-03-16
Inspection 1 @ 72,432 miles, Rovertune Reading, 16-01-17
Oil Service @ 83,872 miles, Stonelake LR Halifax, 25-01-18
Oil Service @ 112,094 miles, Owner Serviced, 08-03-22 (Invoice for parts, Advanced Factors)
Oil Service @ 126,194 miles, Owner Serviced, 09-12-22 (Invoice for parts, Advanced Factors)
Oil Service @ 134,399 miles, Owner Serviced, 08-03-24 (Invoice for parts, Duckworth LR)
Oil Service @ 141,743 miles, Owner Serviced, 30-11-24 (Invoice for parts, Opie Oils)
Invoices for other work -
Adaptive dynamics wiring harnesses replaced, Lancaster LR Reading, 26-05-15
Front brake hose recall @ 43,245 miles, Lancaster LR Reading, 17-07-15
Air Conditioning Service @ 65,248 miles, Rovertune Reading, 08-09-16
Transfer Box Oil Change @ 72,432 miles, Rovertune Reading, 16-01-17
Alternator & Battery replaced @ 77,824 miles, Rovertune Reading, 26-05-17
Front / rear brake discs / pads replaced, 18-03-22
Automatic gearbox oil flush, transfer box, front / rear diffs oil change, Quattro Autocare, 27-06-22
Front suspension arms / ball joints etc replaced, 09-09-22
Wheel alignment, Saltney Tyre Services, 07-10-24
 Jonathan
Post #711485 10th Feb 2025 8:05am
JCW
Photos of rear arches, light scuff on nearside front wing and slight indentation above windscreen.
Apologies for the poor photo’s as it’s pouring down today -
 Jonathan
Post #711486 10th Feb 2025 9:36am
Monkfish
This is fantastic and has all the spec we (well, my family!) would be after once I've sold my 110. I am going to see what I can do and be back in touch, hopefully before it's too late.
Post #711493 10th Feb 2025 12:11pm
DrRob
If my requested rejection is approved then I’ll be over on the train. However, that could take weeks Crying or Very sad Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #711531 10th Feb 2025 9:07pm
manafas
Hello
Very nice car
Where are you based please?
Post #711538 10th Feb 2025 11:08pm
JCW
I’m near Moreton in Marsh in the Cotswolds. Jonathan
Post #711545 11th Feb 2025 7:40am
manafas
many thanks, it is too far for me
Good luck with the sale, car looks great
Post #711557 11th Feb 2025 11:25am
MHT
Hi Jonthan,
I think that in writing this I can send a PM, so will do so now.
Mark
Post #711563 11th Feb 2025 12:22pm
JCW
Received & replied Thumbs Up Jonathan
Post #711564 11th Feb 2025 12:28pm
JCW
Now sold Thumbs Up Jonathan
Post #711984 16th Feb 2025 4:38pm
